View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. Anyone good or alteast know anything about working with fiberglass? or any websites
  2. engine question
  3. It wont stay fired!
  4. white smoke
  5. Look at what some jerk did to me yesterday
  6. What Wing Is This?
  7. 88 si cluster in my 91 hatch
  8. 91 HB lowering help
  9. Fluidyne Half Size Rad doesn't fit. 91 CRX
  10. '92 Civic first time changing brakes
  11. help
  12. 89 Civic SI ZC swap
  13. Need major MPFI swap HELP!!!! PLZ
  14. turbo civic hatch, how fast?
  15. lightened flywheel for zc?
  16. how to build a LS VTEC
  17. Turbo Honda Civics
  18. d16z6--d16y8
  19. Widebody CRX SI FOR SALE!
  20. backseat removal
  21. bumpers
  22. crx seat brackets????????
  23. single wiper on a 89 civic
  24. so what's that nub on the door where the top window is?
  25. Tail Lamp Mod!!...
  26. Question about ZC intermediate shafts
  27. small exhaust
  28. timing belt
  29. how to put cruise control on a car w/o cruise??
  30. 90 Civic is throwing odd ECU code...
  31. can you get a turbo to play nice with a d15?
  32. allright this civic 'z bak in busness well soon enough
  33. 98 Integra b16 swap
  34. Help wiring a B16A1 in my 89 CRX Si
  35. 1993 maxima cam gear set
  36. 89 civic si ZC swap
  37. I have FINALLY chosen my motor after some research!
  38. trade civic for 97 talon
  39. axel problems in my b16
  40. D15B VTEC was rev'n hard until...
  41. what size tire iron do I need for my CRX?
  42. single cam vtec head on dohc zc block
  43. GSR Leather in 91 HB???
  44. clutch and spedometer problem
  45. zc help
  46. 88 4dr civic need help with linkage
  47. Few problems with Y8 swap
  48. Intakes...
  49. STD. Hatchback front end swap
  50. still no hp
  51. Update
  52. Clutch slipping on my 89 crx si!! Please help
  53. Quickest way to reset the timing belt??
  54. 90 civic wont start
  55. Will this instrument cluster work?
  56. mini-me swap
  57. ebay lovers
  58. crx d16z6 swap distributor help
  59. CRX hatch wont stay locked
  60. No codes-Engine Turns-No Catch WTF!!??
  61. Is this right?
  62. accident report!!!
  63. AEM cai or ICEMAN cai ....
  64. Front end
  65. 90 civic water leak
  66. Rear Disc Brake Conversion CRX DX
  67. Swapping steering columns??
  68. Need Help on my Hatch
  69. Previous owner SUCKS!...Help please.
  70. 2 bored 16 year olds, $1000, 10sec crx
  71. 2007 Crx
  72. need head for 1.5L cheap
  73. Got my new car
  74. Been a while... been having some problems with the hatch
  75. wing mod!!!!
  76. smokes on re-acceleration
  77. high idle at startup?
  78. 4g4d update..
  79. NEED HELP WITH MY B16 SWAP IN MY 89 SI HATCH need knock sensor info an ecu pins 4vtec
  80. car overheating
  81. Convertible CRX How To???
  82. I'm in the Fo Do crew now!
  83. Idle trouble..Code 10 and 14!!
  84. If you build it...
  85. what distributors?
  86. sohc vtec time slips
  87. no power after attempted start up
  88. need help
  89. burned head gasket ?!?!
  90. no vtec help!!!!!
  91. Tail light match up?
  92. 97 gsr seats
  93. 89 civic Si wheel bearings
  94. 91 civic clutch help
  95. role cage.
  96. Another rust problem...
  97. Finally got some pics of my GF's Civic up
  98. my heat sensor or somthings wrong help?
  99. Engine Swap 1.5TBFI to 1.6MPFI Help
  100. ride height question
  101. CRX HF Price '88 wit 200k mi
  102. I need help with 90' civic wiring problem!
  103. p28
  104. '89 Civic Exhaust System
  105. Rust
  106. Brake lights won't go off.
  107. D15B2 turbo setup, done correctly
  108. New Car Teaser Pics
  109. Help With Engine Swap
  110. FUEL problem?? Need Help!!
  111. ZC lowest compression motor?
  112. radiator overheating,gushing out
  113. banshee vs CRX fire :(
  114. code 20 on ecu and starting problems
  115. running warm after new water pump
  116. Axels for my b20
  117. will a civic turn signal light socket fit my 89 crx?
  118. steering hub adapter.
  119. what are the symptoms of a bent rear sway bar???
  120. i need help please
  121. blown head.
  122. Gauge Cluster Removal
  123. Thread size for shifter knob
  124. I need info about timing belt on 91 civic
  125. help take off a part
  126. Trade b16a for 300zx?
  127. I know you guys are gonna hate me but here it is...
  128. 4x100 to 5x114 wheel adap?
  129. Sunroof only opens once in a while.
  130. question about Avid motor mounts, Problem
  131. Code 20 on ECU
  132. Help! Car turns over, but no ignition or fuel pump
  133. what is this...
  134. My Ef Civic Suspension. Cry For Help!!!
  135. where is the intake air tempature sensor on a 88 civic Hb Dx D15b2??
  136. Thinking about getting one
  137. highway shake
  138. idle weird
  139. Cam/Distributor Keyway
  140. whats the best cheap motor for 91 crx with some hp
  141. Car does not start always needs a jump ??Alternator??
  142. 88 civic HB DX "im getting 10 flash'es on my ecu... HELP
  143. Clunk after sharp right turns?
  144. B16 runs rich on start-up
  145. XM radio Question...
  146. 91 crx si b16 ecu swap options
  147. got my new audio console today...
  148. Just FYI...
  149. help on my crx's hatchback
  150. just put on a new head now my engine light comes on?? help
  151. Is there such a thing as CRX Shadowline
  152. Can a SI Engine be used with a Auto Transmission?
  153. Battery light on below 3500 rpms, is it the alternator?
  154. obd conversion
  155. thinking of turboing my d16A6
  156. last day for the Duryea Hill climb... whose gonna..
  157. Bad Day, how do i get my hood open without a cable?
  158. breaks , going into the floor
  159. new street fighter kit
  160. Went to the track!!
  161. 91 Crx D16a1 Swap Help !!!!
  162. OBD-0 to OBD-1, Questions about wiring
  163. 4sp 2 5sp transmission
  164. Main Relay---88 HB
  165. Whats going on!!!
  166. P08 ECU pin out wiring diagram
  167. Super Top Secret modification to my car...
  168. 91 CRX Idle
  169. Car spits and sputters once like once every day...electrical or fuel related?
  170. transmission issues and questions
  171. Anyone know what happened to performancepartsstore.com?
  172. A picture is worth a thousand curse words...
  173. New Colour For my wheels ???
  174. License plate ?
  175. What gives?
  176. Valve Adj.
  177. 88 civic wagon died
  178. feul pump upgrade
  179. 89 si hatch blowin boue smoke
  180. 89 honda civic won't cold start for 30 thirty secs??
  181. i hate this crap
  182. Tranny Code???
  183. back seat
  184. Factory CD player
  185. Rotten hoses plague me.
  186. 89 honda civic DX
  187. big update
  188. '88 civic HB fuelpump
  189. Mini Me Swap research
  190. Some Parts Q's HELP!
  191. 4th gen civic/2nd gen CRX Curse continues ...
  192. Quest for GAS MILEAGE....
  193. Anyone do the integra sway bar in a Crx?
  194. Minimum Valve Lash
  195. Smog and Nox
  196. picture
  197. 91 wouldn't start. Now runs, bizarre though
  198. car overheating
  199. Exhaust,Headers
  200. 1.5L ignition burned out
  201. indicator probs with body kits!
  202. 89 CRX W/ZC swap CODE 8
  203. Brake upgrade
  204. what is the best motor for my 89 CRX DX
  205. Sohc ZC probs/questions
  206. How's this for starters???????
  207. '92 integra seats in crx, new bumpers, exhaust, etc. (pictures inside)
  208. Wings West front and buddyclub sides?
  209. 90 civic high hydrocarbons
  210. anyone interested???
  211. anyone interested???
  212. Fuel pump, Crx (dx) soon B18C1
  213. help
  214. need Q & A;s about 1988 crx AF?
  215. b16 tranny fluid
  216. Who has a 91 civic?
  217. quick question
  218. Kilometres per litre??
  219. B16 Crx problem still
  220. NOW this is very interesting...############
  221. what to do ????
  222. What 4-door parts fit a Hatchie??
  223. my car got broken into.. is it easy to break in?
  224. Need To Know!!!!!!
  225. Help? Sqealing noise and knocking... '90 CRX
  226. '91 CRX-Door Speakers
  227. 88 hatchback questions
  228. 91 Civic code question
  229. Help Strange sounds and negative camber
  230. farewell bid to the hatch :(
  231. vtec questions
  232. discolored header
  233. Help, new to Honda's, need motor choice!!
  234. headlight replacement issues!!!
  235. custom console
  236. Civic Pick Up Truck
  237. Long time no post!
  238. New body mods / SHAVED!! PIX Inside!!
  239. My bored summer puttering projects....WITH PICS!!!!!!!!!
  240. Need Help CRX Running too rich
  241. Wheel Bolt
  242. question about HAsport mounts
  243. fuel pressure
  244. Lip question?
  245. crank pulley weight?
  246. Konig GT-R Rims SHOULD I BUY THEM?
  247. Speed cable to speed sensor conversion
  248. can i put a d16zc head on a d15b2 from a 88 civic hatchback??
  249. Drag race Rijeka,Croatia (EUROPE) 30.07.2005
  250. Rear discs
