Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
i'm gettin an arm rest... I'm gettin an arm rest !!!!
just to make sure (shifter linkage)
Car Won't Start!
damn main relay...
Dam Garage Just Charged Me $90.00 For Nuthin
si seats in a cx
Almost did it
got my gtech today (my results)
Warped Rotors need help
connecting air/fuel guage
need a/c im sweatin by balls off
Blown Head Gasket?
Braking shaking and knocking
body kit for crx.
Springs move out of seat???
88 civic DX Gauge cluster
Need online manual
another ECU Question
My brakes are smoking?!
Need Help ASAP
need somewhere to put my arm!
crank pulley?
Which parts switch over?
needed
1.8 clearance
Bent Frame
are these brakes good enough
need help
UK JAp Car show pics (mostly CRX)
H22a dream is commin true!
chiped my B16A1
replacement carpet
engine overheating need help:S
90$ hatch seal???
Fuel pump
Old beater out, new hooptie in
help me plz
abs
Suspension techniques question
ls,rs,gs
Where to buy steering knuckles
Squeaky Distributor?
Y1 LSD in a S1 tranny ?
installing clutch disc?
Body kits for 4g4d civic 88-91
PLEASE HELP!! :important b16a axle question
Axle removal
The Bourne Supremecy: Movie Review
came in second place in the db drag
Clutch questions...........
I got two CRX's problem is...
PepBoys won't align my car
JDM CRX for sale as well as many other cars
fuel, coil, relay????
Confused with camber kits.
seriously off topic car audio question
b16 turbo
Help Me Plz!!!
Maybe fuel?
replacing my d16a6 for a d15b7
help removing flywheel bolts
Painting carbon fiber hood.....?
i need help...
New Interior Upgrade
Finished brake job, but one problem
Hood options...
hehehe i'm a tease :) (pics)
Transaxle mount
Cluster Swap
Need help PLEASE! Mini me probs
Air Conditioning Vents
traitor D:!!
Clutched replaced, reverse now grinding, can't get into gears!
Type of Music
july 31st Bend, OR
I got the car jacked up!
Help me seperate my tranny!
new OEM source...
F/S '99 Black Civic Coupe
Goin to look at a car
code 20
crap Classifieds only thread.
home made ITB
What do the tire numbers mean?
rad swap
TUNER TRANSFORMATION does a CRX
PGM FI main relay fix?
Cast iron exhuast cut-out
HB lowered on 17"s
My New project
1badcrx????
92 ls spindle and callipers.
What Can Cause A Weak Spark
Break Problems
DOHC ZC larger intake/tb cause problems
Howdy Ya'll
Brake pedal adjustment?
[Need Help] Problem after ZC Swap
body kit
Mini me Users --> Was it worth it??
Ebay is going nuts.
88 Honda civic won't consistantly start when warm
z6 head on.. turns over but no start
tire size
RPM Tach...
Help! ZC problem
91 civic info
best for TURBO
electric
O2 sensor questions
5'' tach problem
wich one of these motor is the best set up
exhausts(give me your opinion)
OBD0 to OBD1 conversion having problems.
89 civic won't shift past 3rd tach only goes to 3500 rpms.
What should I set my shocks at for daily driving?
tach problem
The washer trick?
VW lip fits the Hatch!!!
I need a passenger fender for my 91 crx
ZC crank = d16a6 crank ?
Need a beverage holder
b16 parts
1 reason to watch your car at shops....lol
Will obd-1 dizzy fit my crx obd-0
smoking tail pipe
A wierd thought.......
Cars on ebay
Painted Valve Cover
90 std hatch questions
where can you find good alternator for sale for cheap
New Coolant????
mini me swap question with 88 dizzy
d16z6 out of delSol if i use delsol computer...
Radiator fan
gastank question
What OiL and spark pLugs do you recommend?
Tutorial on b16a conversion?
anyone have pics of the R33 style front bumper on a HB?
looking for a a6/b2/b1
Me vs Teg GSR (video)
whats is the zc enigne number
will this center console work?
Positive Output after Start????
which motor should i get?
How much boost???
8 injectors on a turbo si???
91 dx civic for cheap
Grease ball joints/Messed up injectors!
Muffler ?
Parting out an 88 CRX si
making carbon fiber
Where My Florida Peeps??
Female Member Roll Call
body kits
Damn master Cylinder...
gsr brakes?
honda crx si weight deduction
zc or jdm d15b
new reverse indiglos?
ghetto fab no just ghetto
91 Civic HB or 95 Integra
CHEAP Si tranny for sale!!! LOOK!!!
Lights getting yellowish
help i need to replace something and i dont know whats it call'd?
Clutch Adjustment came undone??
romvel of paint
stock wiring harness is 89 rex si
Does anyone have burgerboys printable gauges saved,or know where i can get some?
tranny swap
89 Civic idle problem
what mod should i do next?
check out my new bike rack :)
"DIY" tint
Seat bracket swap
Redline MPH
Is a performance D15 possible in a Sedan
91 CRX Wanted
egr valve
n e body broken a ring gear
is the zc complete swap worth it?
Getting prepared to get to work!
ECU Question
Need advice
Getting a free CRX!!!!!!!!!
Uninsured Girl hit my crx
hood pins
Click here for one dumb question.
body kits
F**K speed camera!!!
HELP!! again. Idling at 3000rmp!! Auto choke stuck on? or what it really embarassing!
need help!!!
questions od legality
serious brake problem..
BHP of ZC dual carb engine
i need advice. gsr vs lsvtec vs b16
nsx tails on a hatch
removal of stock back lights
help broke something i think
rev limiter
frame
Transmission strengths ?
Help me drive
Hiding from me!
anyone have any interest in this ?
Fender Flares
How to:Replace speaker wires to doors and rear shelf - Sedan
honda/acura engine list
any of you guys ever think about going carbed?
91 honda civic rust
I need a td-42u dizzy
help
si tranny
i think i found something here but help!!
Which is an easier color change?
Kind of off topic...
Rex Armrest's
good headlights to buy
its been a while
ZC vs Celica vs Eclipse
replace valve seals
Si cam, with MPFI, Timing cr@p...
What's going on here?
Racing seats
New engine or new car...need help
Strange noise???
Wheels... Brand Name or Knockoff... what to go with?
Carpet question...
I have come to a decision!
have a few questions about the timing belt
BC canada crx si 88-91 to buy
Hey ci5ic come here
bad wheel bearings?????????
Bunch of things for sale! everyone look!!
CRX SIR Seats in a hatch
Lambo style door kits forsale
Wich header to buy (B16A2 in HB) !?
cove 7 on ecu need help.
Another question plz help
N10 Pics (56k mega beware)
Car Died
130mph vs Teg
crx CEL what's this code? help please
NKK Clutches...
Sea Foam?!
My 21st B-DAy today
What is my car worth?
New to forums
automotive primers
Car wont start again
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
