View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. engine swap
  2. d15b vtec
  3. 91 civic dx starting problems
  4. clear corners/bumpers
  5. exhaust sytem for 91 civic
  6. distributor
  7. Blower of Climate Control Out
  8. New rims for me maybe tell me what ya think
  9. haha race video
  10. differential go boom
  11. dizzy question
  12. What's The Diff. Between Ef1,ef2,ef3,ef9
  13. hmmm maaco special....
  14. Idle problem
  15. look at the deal i just got on 2 crx's
  16. need some help
  17. Ignition Box's
  18. 1991 civic question
  19. has anyone ever herd of an SE CRX?
  20. Logical engine swap?
  21. Rough Idle
  22. engine throwing bad fuel injector code
  23. What head will fit "B18A1"
  24. Zc????
  25. New
  26. Stupid Roads.... GRRRR...
  27. rear bumper
  28. Lift my 4wd
  29. shots out of a nos bottle
  30. turbos on vtecs bad?
  31. What mod should I do next?
  32. Suspension lift for 88 4wd HELP!!!
  33. Does anyone have an opinion on Tokico Susp?
  34. Adding More Fuel
  35. Seat covers for 91 civic?
  36. 17" rims on a hatcback, will they rub?
  37. coilovers for my honda civic 91 hatchback
  38. MPH Gauge went out
  39. HUGE PROBLEM - what to do with this engine now??
  40. custom tail light idea
  41. Yesterday was Mod Day (pics)
  42. Idea for our bumpers
  43. Best year for a swap
  44. crazy sound when its cold out
  45. MPFI vaccum hose pics needed!
  46. broke a valve can i use an si head?
  47. how much could i get?
  48. Sleeper Vtec on carbs?
  49. ecu
  50. what size fuel pump in 1990 civic
  51. I highly recommend that all 4g owners pick up the latest honda-tuning!!
  52. My door is broken
  53. does this seam worth the money?
  54. question on wheel stud legnth
  55. what and where is the main relay?
  56. ecu help
  57. help on project hatch
  58. D15B sohc
  59. Anyone knows the different in headlights?
  60. b16 vs b18
  61. 4dr power window tracks in ef?
  62. brake rotors
  63. engine, clutch, exhaust questions!
  64. My front end conversion just starting
  65. help
  66. check out these eyelids
  67. Vented hood and rain
  68. The best brand and type of rotors?
  69. JDM ZC rebuild Question.
  70. Engine numbers help...
  71. Fuel Filter
  72. Tranny bearings
  73. exedy clutch kit
  74. crx hf w/ b16a and 16g turbo
  75. Wheel Bearing replacement..
  76. stock 89 crx bumpers and trim
  77. what do you think?
  78. Does anyone have...
  79. dpfi ecu interchangeable question
  80. Camshaft question
  81. Boom Bang
  82. front disc help
  83. AudioPipe Stereo Stuff?
  84. b16 for 600$?
  85. FYI: CRX Mud Flaps
  86. fagets only own hondas
  87. B18a1 swap into 1990 Honda Civic HB Dx
  88. anyone else get this in winter?
  89. ECU Code Help (PR4?)
  90. Master cylinder problems
  91. bump stop question
  92. Leak test
  93. dyno tunning
  94. dyno tunning
  95. Need help passing emissions
  96. swaybars?
  97. Need help with rim question
  98. i need help!!!!!!!
  99. Good places to byt aftermarket
  100. color code
  101. Code 12 help
  102. Valve Adjustments
  103. Clear Distributor Cap...ITBs
  104. Gathers CD Player???
  105. heeelp: engine swap choice poll
  106. How much would a full set of seat's cost?
  107. Bad vibrations
  108. Starter problem
  109. Auto ZC
  110. Will a 88 to 91 motor fit in and 87 wagon?
  111. tail light fixing options
  112. ZC throttlebody
  113. sohC zc
  114. HELP! Damn Re-occuring Problem
  115. Finally my D15 motor is on its way!!!
  116. Help right now please
  117. alternator ?
  118. need help...
  119. how to tell if fuel pump is messed up??
  120. Crx Dx with Si swap wiring problems
  121. civic dpfi hatch ecu question
  122. cv boot trouble.....help asap
  123. b20 wiring guide
  124. Radiator Shield for Winter
  125. JDM side marker position
  126. Paint engine bay black?
  127. what would cause this??
  128. axle question
  129. Rear tranny mount
  130. Crx Ground Wiring
  131. Pm6 ecu
  132. Pics of the motor
  133. obd0 pr3 ecu throwin a code 9?
  134. good web sites for d series aftermarket
  135. advance or retard?
  136. How do u get the vents off a crx?
  137. A little engine help please.
  138. About Rewireing A Fuel Pump.....
  139. hgth
  140. Gas Smell
  141. gas mileage dropped off
  142. redline help
  143. civic shell
  144. Ahhhh! Wtf Why Now!?!?!
  145. all wheel drive hatch
  146. Check my spoiler out!!!!!!!!!!!!!!
  147. times after engine swaps
  148. Turbo MAnifold for ZC
  149. Check out my civic with accord front lip on my civic
  150. CRX in videogames.
  151. PCV filter/hose help NEEDED
  152. whats smarter
  153. can you do this
  154. SI/ZC transmissions
  155. Finally the Franken Tranny is Done
  156. turbo manifold
  157. b18 help
  158. Motor Mount Inserts
  159. R34 bodykit
  160. crash test rating
  161. modest bodykit
  162. Close Call
  163. oxygen sensor
  164. suspension help
  165. B16a1 difficulty
  166. fuel pump
  167. Battery Placement mod..
  168. Vibration during acceleration
  169. Sound Systems
  170. got a great idea....
  171. Check Engine Light?????
  172. Almost Lost Me Tonight
  173. NEED HELP getting off Transmission Oil Fill Plug!
  174. throttle angle sensor
  175. 91 Civic Si Price Help
  176. 88 hatch swap Q's
  177. dpfi running rough
  178. Check Out My Ef
  179. Insite= the new crx with conversion!
  180. I was wondering if............
  181. pcv valve/hose clogged
  182. CRX Heater Control Removal?
  183. 5th gear problem
  184. good deal?
  185. Aluminum Flywheel Questions
  186. Test Drive
  187. wiring harness for d15
  188. stock hydro clutch
  189. electric load detection relay
  190. Apexi exhaust systems
  191. battery dischrage
  192. 88-91 OEM spring rates?
  193. Anyone got an H22a rex???
  194. rotor size
  195. quick question
  196. Should I adjust valves cold or hot?
  197. are you satisfied with your d15b vtec?
  198. whinning noise, honda civic 91
  199. tire sizes
  200. ZC Oil Pan drain bolt
  201. Civic 1991 starting problem, please look
  202. 16 volt chargeing
  203. low compression
  204. installing new fuel pump??
  205. civic keeps blowing main fuse on fuse box under the hood when connecting to the batte
  206. wheres my oil going???
  207. b18a vs zc
  208. NO power at all 91 Honda Civic, please any help appreciated
  209. 89 integra intake fit a d15 with mods
  210. Hood release cable shot?
  211. questions about crx
  212. Tranny Slips Sometimes!!!
  213. NW civic forums
  214. Speedo? Engine Light?
  215. Car keeps dying on me..help!!
  216. o2 sensor ?
  217. turbo VS supercharger
  218. Spring Knowledge Needed...PLEASE!
  219. my rims
  220. Any Pictures Of 89-91 Civic 4 Doors?
  221. CRX Engine
  222. black smoke
  223. new digi cam = new pics! (56k is okay!)
  224. b16 smog
  225. i'm drunk...sorry to bother
  226. type r steering wheel in 4g4d
  227. more problems
  228. wrecked my car today so no more fourth gen
  229. WTF??? someone explain this to me!
  230. Stating issues
  231. Comp testing
  232. Question about 88-91 crx's and civic hatches
  233. valve cover vent tube Blowing?!? and a code 20
  234. Integra Harness VS civic harness?
  235. aftermarket muffler hanging too low
  236. People Who Have Custom "racing" Seat Brackets!! Help
  237. Anybody have experience with Mitsubishi Starion turbos?
  238. fiberglass work
  239. whinning noise drivers side of engine?
  240. need help with the codes
  241. FREE - Civic for parts
  242. Test ECU,good/bad
  243. alternator help
  244. If I wanted to install my - B18 from my teg, into my civic....
  245. if money weren't an issue which engine..
  246. $250 idk what to do
  247. ZC tranny VS. SI tranny
  248. headers
  249. my car just won't start...
  250. help with my 84 crx looked else where
