Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Honda
Civic | CRX
> '88 - '91 Civic | CRX | Wagon | Shuttlee
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
Distributor purchase?
4-2-1 Headers hang way to low
Darn Seatbelt Warning Keeps Beeping!
Are there high performance axles
shredded axle
After Market Mix-up
Clunk when I shift...
Hood won't open
question about mpfi conversion from dp
Engine bogs and hesitates whn cold
E-brake light stays on
Can I use mixed brands of springs and struts?
Engine building question?
Best place for 12v+ and Switched 12v+ in the back?
Need help installing my cold air intake
Grill Mesh
A few problems/questions.
Other 4 x 100 rims
water in back of my rex
Water in air vents
I made a mistake...now help me do it right..
Looky, Looky what I found.....Concept drawings
Which adjustable cam gear for ZC
possible new car
88 CRX rear brake question/help
hey fuel injector problem
Intake issues
dc sports exhaust
HIN anyone?
check out my custom painted CR-X
Winter Car
Teg dizzy question
distibutor rotor is stuck!!!!!
Si transmission
89 CRX, Fidanza Flywheel #191161, will it work?
engine swap in cali
18 x 7.5 rims
wiring question stump?
sir gauge cluster
need help building up civic
Starter's
weird problem
starting problem, a lil help?
C-Piller Instalation. Asap Help
UGH!!! What axles with ZC tranny?
crx flare fender
crx quarter panel
UnderDrive Pullys
Oh, it's in and it feels good!
New To Hondas, Help me out with a Head question...
Motor Swap Question?
heater
Good Place for Shocks, and Coilovers
oh boy!!
High Idle
Woo Hoo
My Wish List
to vtec or not to vtec
octane rating.
cv-joins going out :'(
sohc pistons in a dohc
racing harness
Code 7
Projector Headlight Type
Headlights Dim
dumb question
touched the speedometer needle
SI brake upgrade
hatch leaks when it rains
Rear bumpers
Rear disc without control arms?
91crxsi need part number for skunk2 camber kit
91 civic hb pics
cel code 8, tdc sensor
heater control help needed!
crx vs alero
Awd Crx?
Exhaust Pipe
Legit Motor or Not?
did I go to cheap?
What Engines Will Fit
dpfi to mpfi
What wires go where?
Tokico Strut/Spring set
dx running like poop need help!!!
Restoring body
Tail Lights
Suspension recommendations
Air ride susp?
Ansa Axle Back Exhaust System - Group Buy
d16a1 and zc
coilovers
ok final thing need help with my swap
Vti
ECU code 23
i need some timing or distributor help
will it fit?
Another odd Swap question
ecu fuse blows
Check engine light...
Loud 1st gear
PG7 or pm6
zc in a 95 civic
96 rhd integra
Best Zc Ecu
Tranny noise
clutch or gearbox problem?
Vaccum lines....
Ecu Reset Question
fixed some stuff...
soild red light
Spot the EF!!
Cheap Swap :( - need of some info
GSR Motor
water gauge
ZC Idle speed (HELP)
H22 in a CRX
zc headaces !!!!!! ecu problems
Omni suspension?
dpfi to mpfi
Auto to manual tranny swap
tein suspensions
Axle back exhaust question
No power to 3K then fine????
valve durations?
88dx to 89 teg"zc"
EACV gone bad?
marble sound + speed sensor?
Stock Parts!!
Distributor Help
distributor
Sir Cluster
hey all i know this is off but i can't make up my mind please help
ZC Tranny
front mugen kit bumper lights
big tach wiring problems
oil dipstick and battery hold down
d16y8 or d16y7 in civic hatcback 89??
some one help ME!!!!!!!!!!!!!!!!!!!!!!! mini-me swap issue!! engine not firing
CRX seats, all the same bolt pattern?
k20 hatch vs. 22psi evo8
88 Civic LX Sedan 1.5 no spark
b16 tach installation prob
b16 Throttle body and alternator questions
any of you guys see this yet..mugen kit...
b16a idle fluxuation
door locks
need help with turn signals and wipers
fuel pressure regulator
Front and rear mud guards.
directions not included lol
Axles colors, is it yellow, red, blue, etc?
zc blue smoke
zc oil pan
ecu throwing a code
need help with mfi swap
Would this work and/or be quick?
need to know which car has ob2 harness?
$550 for a d15b swap
How do I adjust, if my car is running to rich??
Tie Rod End?? Perhaps?
D15B2 with a 4-spd????????
Classified section is back. Sell, trade, or buy your items here.
dpfi into mpfi question
Ls exhaust
I think I am gonna just pull this engine and drop a new one in.
Anyone ever see this kit?
Headers
90 CRX DX Stops at 4000 RMPS
Tran noise
citrus nationals
Going to attempt a rear lip off an accord
Pinging with correct ignition timing
Amazing News Clip!!!!
hybrid d16?
Putting back together the monster
Sirius Radio Install in my Civic
Blowing an engine
Getting some ventshades, but which one?
I'm Bacckkkk!
oil warning after swap
Vibration at speed
Urgent Urgent Urgent!!!!!!!!
bottom strut bolts seezed up
what a nice lookin hatch ^^
sputtering sucks
timing
have a 91 dx swappin for a d16y5 engine need to know do i need if i need obd-0 to obd
Idle setting for 91 crx-dx
h22 swap to 91 4dr
idle problems
waterpump completed on thanksgiving day!
how amplifiers work?
For/Driving Light
vtec question??
Greetings....
'88 Civic hatch...speaker/head unit swap w/newer honda OEM parts?
Civic occasionally no-starts when warm..thows CEL 16 (Fuel Injector System)
What does longblock and shortblock mean?
I feel stupid
I Did The ECU check Finally....
Factory Projectors Baby!
Wonder if you guys are better than the Honda Guys?
Camber problems
ZC swapin
quick distributor question
fixing the gas guage
daily driver turbo
Temporary Pimp Ride (4th gen hatch lovers click here)
How loud..?
Happy Birthday GTA!!!
almost... totally fixed!
confuesed ...cam-to-crank timing???
Still No Heat!!!!!!!!!! Help!!!!!
Integra with B16
b16 high idle comes and goes????
confused on tranny
Prices?
I Need Ideas! Quick!
header??? 4-1 or 4-2-1
Turning on headlights, I drop 500 rpms.
zc is it worth it
Need Help with Headgasket
I need 32 of these and honda want's to charge me 5$ each... HELP!!!
Looking for odb-0 to odb-2 harness
questions on d15b1 > d16z6 parts swap & more
Need help before puttin in hatch engine wise
upgrading a B16a in 89 civic hatch
Yum... This one has stripes!
Is there a way to tell if a block is bad?
max sensor
92 Crx??
aem v2 on a 90 civic?????
Overheating Problem - Help!
1 Stripped Flywheel Bolt!!!
need help with d15 v-tec swap
Pics of my EX's rust problem
will and crx seats fit in my cr-x?
flywheel
d15 mini-me
speed sensor???
B18A twin cam fuel injectors
Too nice for words
why does the hf have mpfi?
ctr hubs
Mazda 626 Heater Core Replacement??
Grinding noise
new door
finally making the jump: vtec
pics of interior
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
