View Full Version : '88 - '91 Civic | CRX | Wagon | Shuttlee
  1. Sorry Guys..
  2. Headlight switch help please.
  3. Car Decision
  4. bogging question.
  5. Need help with engine build
  6. bushings and ball joints
  7. Weird Noise in Wheel
  8. engine question
  9. distributor???
  10. Where did you run your amp wires?
  11. Weird Question
  12. Fuel Pump.
  13. 91 Sedan, Questions.
  14. 88 hatch idle issues need help
  15. 89 dpfi to mpfi please help
  16. security issues
  17. d15 and dohc zc tranny help
  18. mpfi from 1st gen teg
  19. Engine problems
  20. Gas tank question
  21. I got sponsored...
  22. Body Kit Q
  23. crank angle codes
  24. rear bumper support rusted out...
  25. dx/std to obd1 with upgrade obd2 rywire???
  26. 1988 CRX HF Main Relay
  27. Main Relay, To Crank Or Not To Crank...
  28. Best D series traction bar???
  29. zc d15 head help
  30. problem with headlights and blinker
  31. Am I the only one that can't figure out this motor mount?
  32. Mounting new radio?
  33. Hey Guys HElp me out
  34. Fuel Intake
  35. Sunroof Q..
  36. bumpers
  37. Notchy shifter
  38. ecu wiring diagram please
  39. Rev Limiter
  40. Race Car
  41. Hook up Questions
  42. Timing Belt 89 Civic Hatchback...
  43. Tie rod ends and fuel gauge
  44. exhaust bolt springs
  45. gas tank gallons?
  46. wont start
  47. hazard fuse
  48. Transmission compatability
  49. fuses
  50. temp
  51. Few pictures of my new 91 SI
  52. This normal for setting timing?
  53. ecu blinking 3 times
  54. Which one?
  55. My transmission will last a long time
  56. windshield wipers
  57. clicking noise
  58. New project
  59. Auto harness....manual ecu
  60. ecu code 23 on pr3?????what??
  61. Blown tranny?
  62. engine swap advice
  63. problem with new clutch kit
  64. failed smog in cali, here are the results!
  65. What body kit is this?
  66. ecu throwing code 5
  67. Z3 Fenders and body kit
  68. How hot does coolant get?
  69. anybody recommend taking dust covers off brakes
  70. 91 Crx Hf
  71. car wont stay running and plugs look like this after few minutes....
  72. Motor possibly shot?
  73. Integra interior fit in a crx?
  74. gas guage
  75. whats a good fuel pump?
  76. How-to test fuel pressure on my 90 CRX Si?
  77. Good Import Car Club Name?
  78. zc question
  79. Which sensor is this again?
  80. Piston rings? Head gasket? Bent Valve/s?
  81. Seafty cage
  82. Fuel Bar on Intake Manifold
  83. intake manifold
  84. hesitation at low rpm and back fire
  85. tranny question
  86. engine trouble
  87. 1999 V-Tec B16 Ob1 computer setup.
  88. E-brake isnt strong
  89. Rust on the undercarriage of my 1991 Civic
  90. Custom Transmission Gearing?
  91. 89 hatchback standard b16
  92. Brake Noise
  93. looking for starter crx in the ny, nj area
  94. megan exhaust pics
  95. Dash swap
  96. d16z6 vtec head, shot?
  97. ZC exhaust manifold question
  98. friggin' steering knuckle trouble
  99. Which one would be best?
  100. How long will my transmission last?
  101. 91 CRX Overheat
  102. Pulley Question
  103. steering wheel shake, not rotors or wheels
  104. Help Removing Pully
  105. cv joint click, what side?
  106. How much?
  107. 1st gen CRX vs 2nd gen CRX
  108. the newb is back with questions!!
  109. Civic Si Harness compared to Crx
  110. dpfi-mpfi vtec?
  111. Car Truble
  112. Frustrated with Idle
  113. Please Need Help
  114. kyb gr-s bottom bolt
  115. Z6-Fuel, but No Spark
  116. More shiznit
  117. fuel rail
  118. yea i know i am dumb. just answer please
  119. will a 94 teg fuel rail work on a DOHC ZC ?
  120. sticky throttle
  121. muffler on civic hb?
  122. Piston Rings
  123. Guess who's back
  124. piston ring question
  125. Exhaust shiznit????
  126. Can i drive stick shift?
  127. bung hole
  128. Did i get ripped off?
  129. piston question
  130. Newbie Help!!
  131. msd ignition
  132. Not Again!
  133. ground wire ???
  134. carbon fiber how 2's
  135. ZC swap Help
  136. What is needed for a DPFI to MPFI swap
  137. wire harness
  138. Help!!!!!!!!! QUick!!!!!!!!!!!!!
  139. A Little Help Please
  140. 1/4 panels
  141. Dumbest question of alltime
  142. 91 hatch oil buring/ intermitent stalling
  143. what do u guys/girls think????
  144. now it won't start
  145. sir wing
  146. Slammedcivicsi's winter Project ZC 88 Hatch **PICS**
  147. z6/y8 head gasket
  148. Starter Question
  149. steering wheel shakes on 91civic dx!
  150. i've heard that humid exhaust = cracked head gasket
  151. Will a 88 civic 1.6 throttle body work on a 88 civic with 1.5 engine?
  152. what could be the problem?
  153. 14 Inch Steelies, Gas Mileage?
  154. Good deal?? or not???
  155. code 8 need help
  156. Sea foam in high mileage engine?
  157. Please advice on how to replace FUEL FILTER for Civic 90
  158. Poor acceleration
  159. guage face swap
  160. DOHC ZC: PG7 or PM7?
  161. pm8 ecu for mpfi
  162. car update.....lots of pics!
  163. Hard bush set for Civic
  164. Timing Belt *please help*
  165. cluster needle question
  166. Body Shop
  167. '91 Civic DX HB project, B16 swap w/ more to come
  168. intermittent dieing...HELP!
  169. intermittent dieing...HELP!
  170. just a few questions on performance mods/what to do next
  171. Project CRX: Sir II swap with lots of extras in store
  172. Does size matter? (Turbo)
  173. head light bulbs
  174. extended Vtec use??????
  175. Tcu?
  176. how to hide amp wires
  177. How much coudl i sell my front bumper for?
  178. Best Suggestions for a Nice Street Suspension Setup
  179. What's Cheaper??? Turbo or Engine Upgrade?
  180. updates on the CRX paintjob
  181. leaking sunroof!! HELP
  182. Did your ZC passed emissions?
  183. 5 speed clutch
  184. idle trouble
  185. 91 Honda Civic just bought and died twice
  186. Please help!!!!!! NEwbie!!!!!!!!!!!
  187. Custom Body Kit
  188. mpfi auto crx dx 5$ for the answers!
  189. How much would this be worth
  190. How do I change my oxygen sensor?
  191. Whats That Part Under The Tail Lgihts Called????
  192. just look
  193. crx rear disc brakes on a 89 civic hatch
  194. Head Gasket Q?
  195. TRANSMISSION iSSUE
  196. Cylinder Head Stuck On
  197. new hatchie :D
  198. d-series question
  199. Can this be done?
  200. Changing alternator
  201. b16a 88-91 long block
  202. Inhibitor switch
  203. 88 Civic won't to start when hot
  204. Rally Car?
  205. distributor questions
  206. Sedan Taillights
  207. b16a question
  208. shift into rev kills engine with rev light
  209. d16y7 question
  210. checking timing on 91 civic dx?
  211. 91 Civic DX starting problem
  212. error code 7
  213. Help, What is the thing circled in red?
  214. 89 civic si springs
  215. Backed into, asking for estimates on repair costs from you.
  216. b series tb on d series?!?!?!
  217. Body kit and Suspension
  218. Cluster Question
  219. Can't rev past 4500rpm, missing etc
  220. d16z6 swap to d13 shell
  221. throwing a code
  222. Head Swap
  223. b20 info needed and tranny
  224. running light relay ?????
  225. ecu throwing injector code
  226. crx doors
  227. vtech motor for 88 crx
  228. where to buy rebuilt d15b2?
  229. Need Engine
  230. Cylinder Head
  231. running lights, cutting out while driving!
  232. can i get a size please
  233. Valve Cover Cleaner
  234. Snow is no match
  235. 88 CRX Dash into a 90 Sedan
  236. having engine trouble
  237. Out of control idle
  238. d16a6 interchangable with d16z6?
  239. ctr n1 crankpulley
  240. When to upgrade fuel sys.& add adj. cam gears
  241. Hate to bring it back up (pulley)
  242. '91 Acura axles on '88 CRX Si
  243. DOHC ZC Head Swap possible?
  244. quik clutch question
  245. DPFI to MPFI
  246. Starter question
  247. SOHC ZC Questions???
  248. '88 Si W/'91 TEG BRAKES
  249. thought someone might need this (cheap price)
  250. Starting Probs
