Mazda
> 323/Protegé/Familia/Etude/Allegro
View Full Version :
Pages :
1
2
3
4
odd sound from protoge
Protege 5 Blower Motor
Issues with a Protge 96 clutch
2002 Protege misfire
Damn, transmission problem
Replacing a Thermostat?!?!? Help please
Protege5 keyless entry
Thinking about buying a 93 Protege
Key does not turn
I'm a Newbie Who Needs Help
2001 Passenger Mirror
323 body rebuild
1988 Mazda 323 GTX HELP PLEASE!!
F/S: 323/protege bp-t GTX MOTOR + GOODIES
Questions: 2001 Protege/5 Speed Trans Oil Change/Fuel Filter/Wireless Door Locks
P0171 error
1.8 L no spark
First timer! Can anyone help me work out what might be wrong with my 323?
1995 madza protoge distributor
How to change spark plugs
Shop manual - what is available
2001 Protege question
eengine problems on 93 protege
MAZDASPEED MEET @ Tropical Park Miami
my trunk wont open
1995 Mazda Protege Over Heating and shutting off
Please help me identify the origin of a coolant leak
2001 Protege 2.0 liter engine - oil change
white smoke from vavle cover
HELP! 97 Protege overheating!!!
blower motor, wiper linkage. tune up questions
96 protege
Engine Mounts
2000 Protege
will 14inch rims from 1992 miata fit on 1993 323
code 1195
No Turn Signals or Hazard lights...
blow off valve for intake
Cant find the fuel filter
Protege airbag warning light
anybody changed a waterpump on a 1.5?
91 Protege noise when AC is on
what other vehicles use the same part
Changing front rotors ?
Changing sway bar bushings on a 1995 Protege
Timing belt change
the 95 mazda symbol...
Is my 323 got fuel problem?
Horn Problems
is a 95 protege obd 1 or obd 2?
2001 Protege: RPM's High
stabilizer bar in 95 protege
Where is the power steering drain plub?
instrument cluster removal - 93 protege
weird problem in a 323
shifting getting rough
SOHC swap to DOHC
crank shaft seal
re-zero my car comp.
2002 Protege
2001 ES squeaks before downshift?
92 protege
Spastic seatbelt light light - 94 Protege
i need help
replacing timing belt 98 protege 1.8 dohc
bad acceleration!
check engine light 96 protege
Fs: 323 Gtx
93 protege Just started running like crap!! help?
no power to fuse boxes but headlights work
91 protege lx DOHC Firing order?
help with turn signal switch
Protege Vavle cover Gasket
bad gas mileage on 2002 protege5
1999 Mazda 323F LX Suspension
Over Heating 02 protege5
Questions about 323
Need a web site to SOUP UP 94 Protege'
Turbo needed!!!
Locks Don't Work
1988 Mazda 323 GT problem help...
depresurize fuel system on 02 Protege?
After market options for 01 Protege Mp3?
dash light problems
*wanted* looking 4 a 323 GT-R ECU and a wireharness
Removal of Crankshaft Pulley Bolt
97 Mazda Protege Vibrates on idle
1993 Mazda Protege - Temperature Gauge High
Tune-up intervals
Thinking about buying a '98 Protege
Question regarding a 1998 Mazda Protege LX Touring Edition
am i in the right forum for protege5?
2K Pro 1.8L P0171 DTC
PS Pump -- Help ASAP PLEASE!!
escotGT/323 enigine swap
lookin for 323 3 door
Valve clearance.....
South Florida Mazdaspeed Protege Meet
87-323 Wagon vs HB interchangability
Protege 5 starts to shudder when car is warm
Putting New Wheels On
loss of power at low rpm's
Looking for used 323
92 mazda protege
91 Protege wont start
91 Mazda 323 DOHC Timing belt broke...
where have i been
check engine light
1992 protege hood problems..help needed asap!!
FS Mazdaspeed Protege Grand Am Race Car
Dash lights fail after audio upgrade
1992 protege brakes
Annoying Beeping
Squeeking at startup
Engine Swap 03 Protege' (race project)
long warm up period after t stat change
connectin amp to sotck radio/cd
2001 protege mp3 questions
323 GTX stuttering problem (tried everything)
'89 323 runaway idle on cold mornings
Mazda 323 F GT
JOE P. Fuel Cut Defenser for MSP
1991 Protege 4 cyl SOHC Radiator fan
99 protege doesnt want to start when cold
Headlights
'89 323 hatchback
Modifying Ignition Timing
question about fuel injection
FS: 2003.5 MazdaSpeed Protege
1999 Mazda Protege Transmission O/D problems
323 4WD Rear subframe Q
Center Gauge holder?
Protege horn goes off by itself
Premature power door lock module failure
Recommended Maintenance for Protege 2002
WTB-Mazda MP3
97 madza transmission seal leak
97 Protege Transmission
Popping noise from front suspension area when braking...
Please help me.
car keeps dying, help me please reply
91 Mazda 323 HELLLPPP!
Bodykits for -90 BG sedan?
Changing a/c belt to non a/c belt? 1995 protege
car push (noise)
2001 2.0 mazda protege mp3 engine upgrades
96 protege blowing engine/main fuse
1996 to 2002 Mazda Protoges, Any Chronic problems ?
2000 Protege sometimes won't start
Couple of Q's relating to a 97 Protege DX (1.5L)
Just bought 93 323, couple of questions
1995 mazda protege aftermarket parts???
Need Answer Concerning 98 99 Protege
doorlocks/beep unexplainedly lock/unlock
98 1.5L Protege Fluctuating Idle & ECU Reset
Horn Unexplainedly Going Off!
Friend's 93 Protege
2000 Protege 1.6L
1.6L SOHC Head bolt tap size
Shrieking noise,alternator or water pump?
Headlamp problems
Intake for a '96 Protege
FS: 2003 Protege (M-Speed)
Urine Smell
Another Mazda Forum
1.5L Protege Oil Pump Prime
Protege 1.5L RPM's
no spark in my bp
Replacing Front Sway Bar
87 323 Axle bolt torque - for brake disk replacement
1989 mazda 323 fuel system-no gas
door locks that don't work
Need Advice: Rebuild Rack and Pinion (leaking)
Want to buy a Mazda Protege 5
1998 323 bp engine
Stiffness in Automatic Shift
Bolt pattern
possible wheel bearing gone?
98 LX 1.5L 5sp Pulling The Engine
Redline
2001 protege alternator rmv
93 protege short circuit no tail light or dashboard light
body kit installation price
fitting cd plyer 91 323\familia
front whell bearings
Protege - no spark in #1 and #4
Steering Wheel
WTB: Mazda 1.6 (B6) for BG (90-94 323) chassis
Fluctuating idle
Can someone please help me? on the 323's
head light covers
91 Protege DX overheating...
Mazda 323 Familia AWD Turbo Import Model
car wont move
very low idle?????????????????? please help
'91 323 1.8L DOHC 16V "how to" port grinding and polishing
'91 323 speedometer problem
Spark Plugs and Computer
Frankly, does e68, grounding wires, voltage stabolizer work??
1989 mazda 323?
Light Bulb Question
91 Protege LX running on 3 cylinders
no spark from coil
'86 323 won't start
Oil Changes? 2002 Protege ES
1.5 valve lash - $$$$$$$$$$$$$$
at what temperature
87 323 1600efi hard start
97 1.5 a/t hard shifting
97 protege dash light bulbs.
97 1.5 rad fan@@
323 No spark and no fuel
1997 protege good car???????
Remote programming on 02 protege 5
2002 ES - Does it have a timing belt
Cylinder 4 misfire
Timing Belt and air filter
Rubbing Sound When Making a Shaper turn
intake temperature mod(IAT)
Help bypassing ignition in my '94 Protege LX
Engine Swap
1991 Mazda 323 Tachomoter help...
Mp3
Starts then Stops
Website For Mazda Parts
1991 323 sputtering help...
Brake bleeding problem (94 Protege)
2000 Protege Brakse
2001 Protege DX (1.6L) - No hp
brake rotor/pad replacement for 91 protege
'89 323 Engine Ticking, Valves?
car wont start
No Gas!
Mp5 Awd...???
Clutch Cable '86 323
help changing belts
engine swap
engine swap
mazda protege seats in a 323?
'92 Mazda Protege parts for sale
mazdaspeed protege mods and turbo swap
horn will not turn off
Mazda 323 system checker substitute
please help Starting pb ignition?
No cabin heat! - HELP!
'96 Protege Engine
Air Intake Question
think you know your Mazda? Come in and find out..
Spark From Coil vs. Spark from Distrubutor Cap
