View Full Version : Eighty Eight
Pages : [1] 2 3 4 5 6 7
  1. 95 olds still stalls need more help
  2. 94 olds delta 88 running rough
  3. Help!
  4. security system wont start and rough idle
  5. 95 olds stalls
  6. Bleeding brakes 83 Delta 88
  7. Rear brake hose replacement: 83 Delta 88 307 Auto
  8. Ignition Switch
  9. Front Brake Sticking 1990
  10. 83 Delta Brake Issues
  11. 1998 Olds 88 a/c. Weird problem.
  12. 83 Delta Turn Signal
  13. '98 Delta 88 with starting issues... please help? ;)
  14. Delta 88 Turn Signal Problem
  15. Delta 88 Rear main seal
  16. 89 Delta 88 Water Outlet
  17. Transmission rebuild the only foreseeable option?
  18. 1991 delta 88 enigne shuts off
  19. Water In Trunk
  20. body parts for 1984 olds delta
  21. Tips in diagnosing short in Windshield Wiper circuit?
  22. A/C repairs
  23. 1999 olds 88
  24. Ecm?
  25. blower motor stays on
  26. GM Remotes 98 oldsmobile Remote
  27. '97 olds 88 plenum replacement question
  28. 1988 olds 88 won't crank, good battery
  29. One reason why your interior floor is wet...
  30. Need help diagnosing a code 42.
  31. 95 Royal 88 charging problem
  32. Brake Fluid Flush
  33. 97 Olds Dies after running for a while
  34. 1996 Olds 88 Starter grinds won't turn over car
  35. 1998 LSS auto leveling
  36. Replacing DexCool coolant
  37. Is my battery too weak???
  38. 90 Olds 88 A/C oil
  39. 1997 LSS climate control
  40. Opinions about 1996 and 1999 Olds 88
  41. Front End Vibrates 96 Delta 88 LSS
  42. Starts kinda weak
  43. IAC and TPS - 1994 Delta 88LSS
  44. 99 olds 88 throttle body compatible parts
  45. ac recharge procedure???
  46. Weird metal rattling sound
  47. head gasket, replacement sequence
  48. Transmission temperature questions
  49. Question about the grinding AC Compressor
  50. Question about car power at "idle" and rolling
  51. Head gasket/intake manifold gasket blew?!?!?!?
  52. Help, can't find an air intake hose!
  53. 94 Olds 88 Royale Pain, Shuts off when driving around bends
  54. 89 Delta 88 -Service Engine Code 41
  55. Car shuts off itself after a few seconds
  56. 1992 Delta 88 - intermittent shut-off
  57. 1999 Oldsmobile 88 problems
  58. 1988 Delta 88 rough idle
  59. '95 Olds 88' Royale unknown problem...
  60. 99 olds LSS engine swap
  61. Transmission Swap Tips
  62. need help
  63. oldsmobile 88 dies at lights
  64. 95 88 royal A/C issue
  65. 92 olds 3.8 stall intermittant
  66. 95 Olds 88 No power when I accelerate
  67. 1987 olds 88 im lost!
  68. 96 dies
  69. 94 88 knock sensor code
  70. 92 Olds 88 Royale LS Oil Sensor
  71. Summer time REBUILD !! :)
  72. mystery problem
  73. Engine interchange
  74. Noisy in gear
  75. 97 Olds 88 - relay clicking when brake is depressed
  76. Good place for parts?
  77. brake "indicator" light
  78. checking for codes on 94 delta 88
  79. 99 olds lss 105mph is that it?
  80. 99 olds lss
  81. carb identification
  82. 94 olds 88 please help
  83. Turning signals don`t blink.
  84. 1995 4t60e first gear issue
  85. 1999 Delta 88 VATS Bypass Problem
  86. Wobbling feeling on driver`s side wheel while driving
  87. 1995 88 - stalled, wont jump start. New battery, radio works, etc...
  88. Why does my antifreeze in overflow have a pinkish tint
  89. 95 olds 88 Royale - Power problems(car keeps dying)/rough acceleration
  90. 99 Olds 88 will not start.
  91. need help
  92. 96 Olds LSS
  93. 98 Oldsmobile Regency - P0171 code issue
  94. '97 Eighty Eight-Intermittent starting/stalling issues
  95. 1994 olds 88 wont start no fuel mabye
  96. 97 olds lss sc p1811 1645 300 171
  97. Is the alternator the problem/85 Delta 88
  98. 1988 - Poor Heat in Cold Weather - Need Suggestions
  99. Loud (Rough-like) sound when accelerate
  100. Olds to Chevy Swap
  101. Blower Motor Relay Location? '97 Olds 88
  102. OldsmobileDelta 88 1988 3800 V6
  103. Replacing an alternator
  104. NO HEAT IN 1995 Delta 88
  105. 1988 Olds 88 3.8L vibration above 45 mph
  106. da
  107. Itermittent heating issues, 1998 88.......
  108. 95 LSS 88, runs rough when traction control is off
  109. Need info about Eaton M62/M90 snout bearings, Please.
  110. 1995 oldsmobile 88 starts then dies right away
  111. 1992 88 won't start on really cold days.
  112. 1992 Olds Eighty-Eight Royale Leaking Coolant
  113. horn relay location on a 95 Eighty-Eight???
  114. Applying brakes caused car to stall.
  115. Wheel shudder when aplying brakes/growling
  116. fuel filter???
  117. Intermitant Blower on 1999 '88
  118. '95 88 3.8L intermittent stalling/missing -- No codes
  119. 1998 LSS: P0171: System Too Lean (Bank 1)
  120. Timing chain issues
  121. 89 Olds Delta 88 Tranny proglems
  122. Leaky seal - Crankshaft -Harmonic Balancer
  123. 1988 Delta 88 Coolant Leak inside passenger compartment
  124. 1990 Olds Delta88 Cruise Control
  125. 1999 Olds 88
  126. RPM surge when in park & in motion
  127. Climate control whacked after sparks while inspecting CD player. Help!!!
  128. Where is the signal light flasher on 1988 Delta 88?
  129. 95 Olds 88 No overdrive
  130. Code P0305 cylinder 5 misfire on LSS
  131. 1995 eighty-eight
  132. Clunk in front end!! Need advice!!
  133. 3.8L no spark,injector,cranks once a day
  134. How to empty tank on my 89 Olds 88
  135. Delta 88 does not start when hot!
  136. Which engine code engine will work in my 88?
  137. Serpentine Belt
  138. won't start
  139. spongy brakes
  140. Where is the Power Steering Fluid?
  141. Passenger Side Mirror Control
  142. no parking lights and chime will not go off aghhhh
  143. Crankshaft Sensor??? or what
  144. engine stops like you turned of the key
  145. 1998 Oldsmobile Fuel Line
  146. a/c switch went out suddenly?
  147. Transmission type
  148. 1996 olds 88 unusual noise
  149. Climate control blower intermittent when hot
  150. Front wheel bearing/smoke through ac vents
  151. 1998 Oldsmobile 88 Intake Problems
  152. 1998 Olds Eighty-Eight high-speed fan doesn't work
  153. Remove Power Steering from 1997 Olds 88
  154. 96 olds lss fuel pump issues maybe
  155. 88 Coolant Loss
  156. Running Rough/Stalling Out.
  157. Broken Bolt - Intake Manifold
  158. 1996 88 barely runs rough idle
  159. Engine Line On
  160. 97 LSS blower motor quits, overheats, looses power
  161. 1992 Olds 88 Transmission
  162. 1989 Royale Brougham 88 Stalling Out
  163. Any way to disable DRL's on 1999 eighty eight
  164. 94 88 transmission swap OBDII OBDI
  165. Security light
  166. One last check before I sell it.
  167. p171 lean code -My Unusual Problem & Solution
  168. A/C Compressor noise (metallic rattle)?
  169. Mysterious no start 1996 Olds 88
  170. AC died in 93 olds
  171. Blower motor relay keeps burning out
  172. 97 olds 88 blower motor runs with ignition off.
  173. Engine Knocking Sound
  174. HD radio???
  175. 94 LSS sputters out of idle
  176. 98 Olds 88 Ls- Console Shifter
  177. 98 Olds 88 Ls- Climate Control Upgrade
  178. 1991 Olds 98 Regency
  179. fuse 14 keeps blowing
  180. 97 Olds 88 Fuel Gauge
  181. Traction control switch on 95 LSS
  182. 1992 oldmobile delta 88 royale ls
  183. 89 Olds 88 Code 41
  184. Reusable trans pan gasket?
  185. brake question
  186. 94 Sputtering Problems over 50MPH Runs Rough, Hot
  187. Wierd Problems
  188. 93 Olds Blower Motor Will Not Cut Off
  189. Brake problems
  190. 1998 Olds Regency
  191. Harmonic Balancer Bolt
  192. 88 1997 Side Veiw Mirror Replacemen
  193. 1992 Delta 88 - climate control flashes?
  194. Help! 92 Olds 88 terrible gas mileage
  195. 1990 Royale 88 trunover won't start
  196. 1998 Olds 88LS Starting Problem
  197. Emergency Fix on '93 Delta - Releasing Tensioner
  198. Fuel Pump/Filter
  199. GM Intake Gasket - Engine #2 (is 3 coming)
  200. 86 olds 88 no spark
  201. 1997 olds 88 dies/wont start
  202. Best replacement plenum??
  203. good site?
  204. 1992 88 royale ls inside door panels
  205. 3800 "C" into "L" code 92 olds
  206. 1990 Delta 88 Check Engine Code 42 ?
  207. Window motor is broken
  208. 1996 Olds 88 3.8l Pinging
  209. Starting/Acceleration Problem for '96 OLDS 88 Part 2
  210. 1988 Delta 88 Won't Start
  211. Plastic Door Covering Repairs
  212. 1985 delta 88 jerks and sometimes stalls
  213. 1995 olds 88 royale temp sending sensor
  214. 98 Olds 88 LS Blower Motor Replacement
  215. Aftermarket radio install problems
  216. Starting/Acceleration Problem for '96 OLDS 88
  217. 99 olds 88 3800 missfire at idle p0301
  218. 1993 Olds 88 Low coolant light and floorboard rattle
  219. Transmission swap!
  220. what is this
  221. 1995 Olds Eighty Eight Royale
  222. 1990 Royale 88 won't start
  223. what, harmonic balancer
  224. NOISEY 98 olds LS - OIL pressure?
  225. Cam sensor
  226. 1994 Old's Axle Shaft
  227. 1995 olds 88 royale temp sencor
  228. 1994 Olds 88 4T60E Trans Problems
  229. code 171 rough chugging start
  230. 1996 Olds 88 W/ 211,000 miles
  231. Starting issues & other??'s
  232. firewall wiring
  233. inner joint on cv axle, is it in all the way?
  234. 1988 Olds Delta 88 Royale won't start.
  235. Starter Issues?
  236. Posting in Old Threads
  237. 95 88 royale starting
  238. 86 olds 98 regency popping noise at throttle body
  239. newly acquired 1997 88 need help with a few issues
  240. 92 olds 88 replace/repair speedo head only?
  241. opera lights out
  242. How to tell if keyless entry was an option
  243. 83 delta
  244. 1992 Olds 88 Dead after attempted jump start.
  245. Intermittent elec. problem NO HEAT below zero!!!
  246. 1999 '88 blower fan problem
  247. olds Delta 88 Heater problems
  248. 97 Regency door key alarm disable
  249. 92 royale
  250. how to replace electric side mirrors
