View Full Version : Regal
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12
- 1991 Buick Regal, 3.1 V6 - Stalling at Idle.
- doing engine swap
- brakes
- 93 Regal Keyless Receiver Location
- Engine Swap.
- 94 Regal Custom Won't Rev Above 4000
- tranny slips when cold
- Blinker Shuts off Engine
- Temperature needle pegging
- SVS, ABS light on
- need part number for bypass hose fitting
- 93 regal, cranks, no start
- 1991 Buick Regal Gran Sport
- 95 regal 3.8 oil pan gasket
- Rear Defogger
- Key gets stuck
- harmonic balancer
- 1994 regal custom p/s hose
- Removal of door panels
- 2001 regal gs P0410 code
- Aluminum vs. plastic intake manifold 99 regal
- 96 Regal signal light switch
- 1993 buick 3800 gs wont keep running
- changing fuel filter 2001 regal
- 94 regal custom might be losing coolant
- shutting off.
- Abs/service Vehicle Soon/trac/brake Lights On
- 84-87 Regal Blue velour Bucket seats
- 1999 buick regal radio
- 83 brake problems
- Lug bolt on 98 regal
- 83 regal and 350 motor mounts ?
- Problems with flushing antifreeze
- 94 Regal won't start when hot
- 97' Buick Regal Mod Questions
- 1993 Buick Regal
- how much coolant for 99 regal gs
- Fuel pump shutting off after start.
- Buick
- possible bad oil pump
- 99 regal gs supercharged help
- 1988 Buick Regal No Spark!!!
- 93 problems
- 87 Regal Heater core replacement
- 94 Regal 3.8 intake coolant leak
- tire question
- Remote programming for 94 buick regal
- Acceleration Problem
- 1998 Regal LS - Odometer Problem
- 1998 Regal LS - Fog Light Removal
- Exploded Picture of Regal 95 Rear Brakes
- Yet another problem! (weird electrical ignition issue)
- Problems with MAF Sensor
- Help with my buick
- Signs of a bad alternator
- 02 Regal accleration problems
- 98 Buick Regal LS Transmission Problem - New Issue
- How to Remove Power Window Regulator '97 Regal
- Tranny issue....maybe
- 1998 Buick Regal Trac Lite noise when stop
- Air bag and SES light on constantly
- ABS Removal
- Need Some Help
- OBD II protocols
- odometer/gear selection light
- Dtc 1441
- 2000 Regal Ls - Performance Upgrades
- 91 Regal stalling
- Dash/Gauge problems (gas, oil, etc)
- Strut Mount Replacement help Plz
- 99 Transmission Bad?
- Problem with dual zone climate control
- 98 Transmission Problem
- 1995 Regal Custom Transmission Shudder
- Exhaust Questions
- Replacing inner tie rod
- Changing spark plugs & leads, probs rotating engine
- 2000 - accessing behind the glove box
- Purchasing 99 Buick Regal
- Dashboard...
- SES Light on.
- fan blower
- Help!Regal Dies when driving slow/ while stopped
- Steering noise
- Intake Leaking?
- Replacing gas tank on 92 buick regal
- Buick enthusiast or good mechanic
- CV joint info or part #?
- motor mounts 3.8L Buick Regal
- torque convertor lockup problem
- Coolant flush Regal 2001
- 1999 Buick Regal LS
- Valve Rattle:
- brade rotors rust?
- Clicking Noise on Startup
- Re: performance upgrades on 96 regal 3.1
- Clean contacts on ignition switch 97 Regal GS
- Speedometer Malfuction
- a/c quits on 92 regal
- Changing rear leaf on 96 Regal
- problem with regal and 350 and the flywheel
- 91 GS is posessed! (anyone know an auto exorcist?)
- replacing the fuel pump
- 1991 Buick Regal 3.8 stalling / no start hot
- no EGR?...
- 93 Regal dying
- 1985 Buick Regal street/track
- 98 regal LS wont smog
- Wobbling 91 Regal
- Tires
- 1994 Buick Regal Please Help
- 2000 Regal GSE Speakers
- 98 buick regal AC one side cool
- 92 Buick quits when hot
- '92 Regal GS with rear disc brakes......
- 1992 Regal Custom makes strange noise when turning wheel
- bucket seats and dash trim for 1980 regal
- Changed rear strut...now wheel is turned inwards on 96 Regal
- pully
- 00 Buick Regal SES code 0440
- need to know a part name
- Where is body control module on 1994 buick regal
- AC/Heat blow all the time
- 1994 Regal GS Brake Light on? Any thoughts?
- Sounds like a race car
- 87 Regal Rear Parking Lights don't work
- 2002 GS Brake Question
- 3800 mods to an olds 88
- How to remove interior trim in a '96 Regal
- 90 GranSport overheats in traffic
- need help with air bag code b1001
- 98 GS Driver Information Problem
- Changing rear high mount brake light in 95
- 91 Regal 3.8L Possible MAF Sensor Problem
- 92 Regal Custom Odometer malfunction
- problems getting key out of ignition
- 99 Buick Regal Power Windows
- Fuel line repair
- new 85 regal
- ALT. has effect on ABS/TRAC?
- Are all 4 hubs the same?
- 2000 Regal LS 3800 SII Won't Stay Running
- 97 Buick Regal Front Clip Removal Help
- Just bought a regal
- How to change a headlight bulb?
- 82 Regal Overheating
- 88 Buick Regal 2.8L V6 2 door electric locks...
- 93 Buick Regal Starting Problems
- 93 Buick regal 3.8 liter won't start
- air bag question
- Odometer getting dim 01 regal
- Floor Jacks and Jackstands
- 2000 Regal Blower Motor
- Air Conditioning problem
- Tensioner Pulley Size?
- 93 Buick Regal Custom vacuum
- Motor swap info on regal?
- 1999 3.8 GS engine surging
- Problems with an 88 regal
- Dex-cool gone wrong
- Suspension upgrades?
- Starter Replacement
- 93 Buick Regal Not Starting
- Gas Gauge fuse
- dash lights
- turning over problems
- To all AF brothers
- 1994 regal GS Not Starting at times
- regal GS Power window problems
- Hello All Problem w/91 regal custom no codes PLS HELP
- HVAC Max/Min switchover
- Need help with my 94 Buick Regal
- Speaker Removal Help
- 98 regal gs
- Power Lock Problem in my 93'
- 93 regal remote programming
- Battery problems with 94 Buick Regal???
- 2000 GS oil leak
- changing the prestone
- fuel gauge inop
- my car shuts off at 110
- New Struts! Ride N/G!
- 1995 keyless programming
- regal 1-4 coil problem
- A/C refrigerant
- 96 Regal 3.8L coolant fan won't come on
- 91 buick regal starting problems
- Problem with vents in 96 Regal
- Ignition 94 regal 3.8
- Gas Gauge Broke
- Awesome site
- stuck ignition key is regally a pain
- AC only blows on passenger side
- 1996 regal overheating problem!!!!
- 1994 Buick Regal Grand Sport Starting Problems
- new key fob
- New and Old Members Please Read
- Key Fob - 2000 Regal LS
- 1996 keyless entry programming
- interior auto dimming rearview mirror
- 2000 Regal Clicking On Passenger Side
- HP Difference Between 3.4" and 3.25"??
- 1999 Regal Speedometer, Trip, Odometer Quit Working
- 2000 buick regal fuel gage
- Monsoon Sound System??
- GS Power Upgrades?
- 92 regal 3.8 stall RPM Signal Problem
- 94 Regal Custom A/C Condenser
- 126k too much?
- buick whistling with rpm
- 1999 Regal GS Rear DS Window Falls
- SES light on, what do I do?
- Fuel Filter
- fuel problem?
- Weird clicking/humming noise from driver side {no clue}
- High Idle!
- '92 Buick Regal Windshield Washer Problem
- Removal of Front & Rear Knuckle Rod Arms?
- 94 Buick ABS/Brake Light
- Power Steering hose replacement
- I have a 1996 Buick Regal that give me starting problems
- Car stero install helpp.....!!!!!!
- Regal 93 water pump / belt slipping
- LOW TIRE light after Hub/Strut replacement
- ECM BAT fuse keeps burning out
- Low Oil Pressure Once Warmed Up
- 1990 Regal Custom 3.1 stalling
- Highbeam Issues
- 93 Regal Brake light
- Jumpy Tach on '97 regal 3800 series2
- 92 Regal 4t60 / 4t60e swap
- 90' Regal GS a/c compressor HELP!!! PLEASE
- How to remove ignition switch?
- Can failed knock sensor cause no spark?
- 94 Regal Custom Electrical?
- Misfiring Piston?
- New Cat and O2 sensors?
- Transmission louder shifting
- Can you remove windage tray next to oil pan?
- Obsessive Blow outs
- what is your gas mileage on ur buick?
- 91 Buick Regal Limited Cam Sensor Question!
- 1994 Buick Regal GS 3.8L
- 99 regal - changing front signal
- cant remove my ignition key
- Front Strut Bushings?
- 1996 Regal not start when it is hot
- New steering column...
