Old 01-25-2002, 08:03 PM
fakirone's Avatar
fakirone fakirone is offline
Send a message via AIM to fakirone
First of all, the best power, torque and rpms for the moneywould be the LS/VTEC style motor with a B20 block and a B16b head (any B series head is good but that's just my favorite). With the B20 you get the added displacement and torque of the 2 liter motor, then the B series head gives you the higher hp and revs.While keeping the wieght to a level that the Civic chassis was designed to handle.This set up costs less than most other motors and is far superior in my opinion.
Yes, the H22 is a heavier motor but that's really not the issue, the issue is that it's heavier OVER THE FRONT WHEELS. This creates a wieght transfer problem when cornering and understeer in our little cars. Autocross is based on momentum and horsepower so understear even a little bit of it is a huge problem.
Another thing to remember is that the H22 (the engine built for the Prelude, Accord chassis) sits different than a B series (engine made for the Civic, Integra chassis) so it's kinda hard to fit in there and to get the wieght and motor in properly.You also lose your AC ( there's no room for the compressor)
Once again, nobody paid any atention to what this car was going to be used for, he said that he wanted to drag this car, with a turbo and nitrous.So in this case the negative for handleing in turns is turned into a positve for putting more wieght onto the front wheels, which we all know gives you better traction. The added displacement of the H22 will help out greatly in your ability to make torque (a huge deal for drag racing) and I believe that hondaspeder is right about the closed deck, which is good for turbos.
If your serious about drag racing and building a drag car then the H22 is DEFINATELY the way to go it has everything that you want in a drag motor and it's fairly cheap (around $2300 depending on the model).
Anyways who needs airconditioning in a drag car?
'93 Delsol (motors blown)
"FAKIRONE"
IBG-PUHD-DOE STREETLIFE CRUISE CLUB-PUHDLIFE RACING
pain is temporary,chicks dig scars,glory is forever.
check outthey rule.
Old 01-25-2002, 09:33 PM
Hanguk87 Hanguk87 is offline
Personally, I would get the B20. I heard that when you get a VTEC engine and turbocharge it, you gotta like change the VTEC stuff and shit. I'm not an expert on that but all I know is that you gotta take it out or some shit.
Old 01-25-2002, 10:29 PM
fakirone's Avatar
You dont have to take out the VTEC, you should lower the compression though. You don't really need to until you get to the higher bost level sthough. The reason is, that it's easier to get detonation (that's bad) with a higher compression ratio.
There are lots of turboed H22s drag racing and they do VERY well.
"FAKIRONE"
check outthey rule.
Old 01-28-2002, 02:28 PM
ViperGWSS ViperGWSS is offline
Send a message via AIM to ViperGWSS
So.........
So you think going with the H22 is the best way for me to go? Actually in a 92-95 civic coupe obd1 h22 is the way to go as I've heard. And as you have heard I am not racing or pushing the car around turns. Only letting it out on straightaways and tracks :greenchai :flamer: god I love these things.
Old 01-28-2002, 02:34 PM
Why not a H23? More displacement.
Old 01-28-2002, 05:44 PM
VTEC_boi's Avatar
VTEC_boi VTEC_boi is offline
Send a message via AIM to VTEC_boi
H23 is SOHC....
Fakirone...i like the B20 w/ VTEC head...but it's just CRVTEC :P instead of LS/VTEC
I'd stick with the good old B18C + turbo if you really don't want to experience some more different motors.
the B18B1 (LS) is always good.
Or..lose your A/C and PS and go for the nice..big H22 It's great for straight line...
And..just get a 22mm rear sway bar to help with that understeer :P muhahahahahaa!!
"Son, your eyes look a little red there. You've been hittin the Vtec haven't you? Alright, stand on one foot, touch your nose and say 'Third Rocker Arm'".
Original PH Member (Reppin' for original PH'ers!)
www.lunspeed.com
www.jdmcivic.com
www.sweetcarz.com
Old 01-28-2002, 06:06 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Originally posted by VTEC_boi
H23 is SOHC....
H23 is DOHC non v-tec! Since your goin to use ur car on the track then h22 is a good choice.
Old 01-28-2002, 07:58 PM
H23? could I have some info on these and if they'd work in a 92-95 civic? prices? places?
Old 01-29-2002, 12:02 AM
seantree seantree is offline
i am also greatly interested in the h22a or cr-vtec for my 93 hatch. I was looking into building a crvtec but can't seem to find anywhere to snag a vtec head at. i found the longblock, the pistons i want etc.. but no head. any info on the h22a or cr-vtec you guys can offer up would be appreciated. i'll have about 3k to do this motor swap up with and it'll be here in like 2 weeks, i'd like to be decided soon. thanks
Old 01-29-2002, 01:35 PM
fakirone's Avatar
The H23 is a 2.3 liter DOHC non-VTEC motor. It is what the B18b is to the B18c.
You can do the same frankenstien stuff to this motor that you would do to a LS or a CRV motor. You take the head from a H22 and put it on a H23 head on it. The benifit of this, is increased displacement and more torque. This is THE BEST option for drag racing but it's not that much better than the regular H22.
The H23 should cost you about as much as a H22 and the instalation is very simalar. Then youve got to have the H22 head put on. I don't think that it's worth the money to do the H23/H22 unless you do not have budget concerns.
"FAKIRONE"
check outthey rule.
H22 motor w/ h23 trans||h23 wired for vtec? ||h23 2 h22 any ac problems?||H23 axles o sprayedlude93 Prelude 9 12-03-2004 12:07 PM
All motor H22 vs H22 turbo? JDMugenKid Let's get Technical! 6 01-30-2004 11:32 PM
How tell a JDM H22 or USDM H22 mast0075 Engineering/ Technical 8 12-17-2003 11:45 PM
V-spec h22 vs Jdm h22 type s prelud-a-cris Engineering/ Technical 4 10-23-2003 09:29 PM
orderin an h22 off net....which place is best to get the h22 from Atariallstar Engineering/ Technical 11 10-10-2002 09:54 AM
