Old 12-15-2003, 12:07 AM
mast0075 mast0075 is offline
Send a message via MSN to mast0075
How tell a JDM H22 or USDM H22
How do you find out if i payed or H22 JDM and Not H22 USDM
Has any one every looked in to that or any one know more about these Engines.
Old 12-15-2003, 01:06 AM
michaelsd16c michaelsd16c is offline
well jdm motors just say h22 and usdm say h22A. Usdm motors but more letters on their motor (example jdm b16,b18/usdm b162(?don't remember),b163(del sol or SI)b18b(ls)b18c(GSR)b18c5(ITR) I hope this helps.
Old 12-15-2003, 01:52 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: How tell a JDM H22 or USDM H22
Damn, MTV get off the air.
JDM motors don't use the number at the end, so it will be a H22A, not a H22A4 per say. B16A, as opposed to B16A2, A1, A3, A4 etc...
Old 12-15-2003, 02:50 PM
Cool Thanks for your help.
Old 12-15-2003, 10:00 PM
BabyLex85 BabyLex85 is offline
aight my question is just bout the same....
so if the engine code is B18C and it'sa JDM engine then that should be the ITR right? so what would the JDM GSR engine code be if they don't used the numbers to differentiate the C1 from the C5?????
Old 12-15-2003, 10:31 PM
well I not sure but I think that it's the same as a usdm which is b18c5 plus the val cover would be red because it an ITR. B18c or b18b would be black. And yes some could change the val cover.
Old 12-16-2003, 02:08 AM
o tell the differences betweem a GSR and an ITR is easy two things to look for, one is the intake manifold, the GSR's folds under...
And the ITR's is more normal looking...
Also on the ITR you can look for the head stamp on the left side, it is a PR3-3.
Old 12-16-2003, 08:09 AM
great thanx guys
Old 12-18-2003, 12:45 AM
Got The JDM H22A And i got the car back monday night and Every thing look Good. Only thing is not hook up for some reason is Cruise control. It turns on when i press the switch but it won't hold. Any one know what need to done for manual tranny to work with the cruise cause it was hooked up to my AUTO tranny before i got the swap done.
jdm h22 help sanchezjarodsdad JDM Motor & Parts info/chat 4 04-09-2009 06:14 PM
How to tell the diff. from JDM type S H22? SBallerk2 Prelude 13 12-14-2004 12:23 AM
how to tell civic jdm and usdm clocks apart? bionictony '88 - '91 Civic | CRX | Wagon | Shuttlee 3 10-22-2004 05:55 PM
jdm or usdm h22, help!!!!!!!! crazyH Engineering/ Technical 26 04-01-2004 01:46 PM
