Old 03-28-2003, 08:51 AM
GENONCARL GENONCARL is offline
Banned
cam shaft and cam gears in b16a
Im picking up a b16a1 from LA and thinking of replacing cam shafts and cam gears. I was thinking of skunk2 are there any better brands out there. do i need to replace anything else if i do replace cam shaft and cam gears? What other mods can i do to gain hp and torque?
Old 03-28-2003, 11:36 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: cam shaft and cam gears in b16a
skunk2 is a very good braned, but it depends on how "wild" you want your cams. i personally will be running ctr cams in my car, but those, JUN, Spoon are all very good brands along with others.
cam gears are not really needed unless your car is heavily modified. when you take your cams out, you should replace the seals and the valve cover gasket while its off.
there are plenty of mods that can increase hp and tq, it all depends how much money you can spend, and how you want your motor to be set up, all motor or forced induction.
i hope this all helps.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
2003 GC in need of valve and cam shaft replacement cjwalker Grand Cherokee | Grand Cherokee SRT8 2 12-19-2005 07:56 PM
2003 requiring new valves and cam shaft cjwalker Cherokee 2 12-06-2005 09:14 PM
manifolds and cam shaft Z32TT_maniac 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 7 11-20-2004 07:08 PM
Lowering gear ratio and street legal cam shaft 94CamaroZ28 Camaro Discussions 14 04-19-2004 10:30 PM
how to switch out a cam shaft or a cam gear o0Quicksilver0o '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 01-22-2004 11:00 AM
