Old 02-07-2003, 11:14 PM
4thgenlude 4thgenlude is offline
Send a message via AIM to 4thgenlude
compression
i have a question about compression ratios. Im asking with turbo in mind. If i get the bigger 11.5:1 compression pistons will it give a better performance than a 9.0:1 compression?
Old 02-08-2003, 12:32 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
you cant run a turbo with a high compression ratio....you really dont even want the stock 9.0:1 if you can help it...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-08-2003, 01:23 AM
so basically im better off with the biggest compression i can get?
Old 02-08-2003, 11:58 AM
threethirteen's Avatar
threethirteen threethirteen is offline
Send a message via AIM to threethirteen
no, the lower the compression the more boost you can run. you can run with higher compression but it isnt as safe or good for the engine. the lower the compression you can get is better for turbo.
Letting micheal jackson in into disneyworld is like letting a kid in a candy store...or like a child molester in a candy store...looking for kids.
Old 02-09-2003, 02:09 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
it depends on how much boost you wanna run, say like you only wanna run like 8psi, then you wanna get your comp ratio as high as you can safely, maybe like 10.5 or soemthing. but yeah you wanna get your comp ratio is high as you can but safely, like no detenation
Old 02-09-2003, 11:54 PM
b16a3sol b16a3sol is offline
lowering compression is strictly for a safety reasons. the only way to get more power out of a motor is to compress more air into it so more fuel can be burnt. lowering the compression creates a drop in power, while raising boost compensates for this loss, rather than creating more power. a general paradigm on this board seems to be that more boost automatically means more power, even if it comes at the cost of lowered compression. this is untrue, however, because of the linear relationship between air and fuel. whether the air is comressed before it enters the cylinder or not doesnt matter, its solely based on the pressure during ignition. the goal when building a turbo or super setup is to have as high of a compression ratio without achieving detonation, as civickiller was saying. what that compression ratio is depends on the setup and how well its tuned.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
compression ratios and method of compression SPOOK(I) Impreza/9-2x/Outback Sport 2 05-28-2013 07:26 PM
1986-old low compression 305 lee32 C/K 2 06-13-2009 08:01 PM
high compression vs. low compression on turbos rice(er) Forced Induction 9 09-16-2005 11:12 PM
what is the different from high compression and low compression djkarlkani Integra 5 11-04-2004 02:27 AM
LT4 compression Vs. LT1 compression DVS LT1 Corvette 1 06-30-2003 03:21 PM
