Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-01-2004, 10:31 PM
djkarlkani djkarlkani is offline
what is the different from high compression and low compression
what is the diferent from high and low compression. Can someone explain why low compression is better for turbing up. i got a ls b18a with 270,00 miles should i try building and turboing or should i drop it.
ps. what engines are high and what are low compression
Old 08-02-2004, 12:42 AM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
Re: what is the different from high compression and low compression
when u turbo, it forces more air into the combustion chamber. if the compression of the chamber is already high and you force more air into it, then you bust your engine. it can only take so much compression.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 08-02-2004, 06:31 AM
94tegRS's Avatar
94tegRS 94tegRS is offline
yeah, low compression allows more boost, while higher compression gives you more power in NA setups. there are limits as far as tunability and drivability at both ends. also if you got 270k miles I wouldnt do anything to it until I gave it a full rebuild. Id never throw boost at an engine with 270k on it.
for examples, B20B is 8.8:1, thats low, and the RSX type S is 11:1, that is high.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 11-02-2004, 08:31 PM
silver bullet LS silver bullet LS is offline
Banned
yea thats why im doing a ls turbo, so i can get that massive air induction into the combustion chamber with low compression. Damn i do love type r all motor.
Old 11-04-2004, 01:13 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
also remember to use higher octain gas as the compression goes up to reduce chance of detonation and carefull with jdm's they run higher comp than there usdm counterparts you can run high comp and forced induction but you should sleeve it or run low boost.
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 11-04-2004, 01:27 AM
integralover's Avatar
integralover integralover is offline
that is why i'm going to turbo my b20b. gotta love the 8.8:1
93 teg LS
B20B
ACT Performance Flywheel
AEM CAI
DC Sports Stainless Steel Header
G4 High Flow Cat
GReddy MX Cat Back Exhaust
Skunk2 Racing Chip
Lots of interior goodies
