Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 07-23-2007, 08:29 PM
SPOOK(I) SPOOK(I) is offline
Question compression ratios and method of compression
For those of you who are not afraid to rip apart the block for more power, higher compression can help. On this note, i have a few questions.
1. What compression ratio's are you guys using?
2. How did you achieve said ratio(i.e. "stroker" crankshaft, longer connecting rods, custom pistoms, shorter cylinders, etc)?
3. In the Automotive Encyclopedia i have, it says that General Motors did several experiments many years ago and decided that in gasoline engines, the optimal compression ratio was 17:1. Have any of you actually gone this extreme? if so, how and what are the results?
Thanks to all the people on here who have taught me so much, and will (hopefully) continue teaching me for years to come.
Old 03-24-2012, 11:50 PM
z28Nemesis z28Nemesis is offline
Re: compression ratios and method of compression
that's crazy. Highest compression ratio I've ever personally seen was 16:1 and that was a diesel.
Old 05-28-2013, 07:26 PM
brokenboxer01 brokenboxer01 is offline
The compression ratio's you speak off, would never be driveable on a day to day basis, nor affordable or reliable. As compression ratio goes up, so does the chance of detonation. Detonation is the enemy. High compression on a Subaru is a silly concept. The road as already been paved, low compression and boost. All motor Subaru's stop at around 200WHP, at these levels the investment would have been better spent.
