Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-15-2005, 09:16 AM
rice(er)'s Avatar
rice(er) rice(er) is offline
high compression vs. low compression on turbos
why is it so bad to turbo high boost on a high compression vehicle? if you have a high compression car and running low psi, would you be safe? as far as i know from reading around the forums is that....low comp = higher boost .......and high comp = low boost.....<---this correct?
Old 09-15-2005, 01:38 PM
flip888 flip888 is offline
Re: high compression vs. low compression on turbos
Id also like to learn more about this but from what i know, the most important difference between having lower or higher compression is what grade of fuel you need to prevent detonation since when you compress air, it heats up so much. So i think your right about high comp means you can run less boost, unless you run high octane with the high compression engine.
Old 09-15-2005, 03:00 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
think about it
when you compress a gast say 11:1 you are multiplying pressure 11 times. atmosphereic pressure is about 15psi (a little less) so when you compess it 11:1 you have 161psi pushing out on the gasket and heads and only 15psi pushing back in...
now add some moderately high boost, say another 15psi, now you have 322psi pushing out and still only 15 pushing back in...too much and a blown head gasket is a guarontee.
on top of this all of that air being compessed causes alot of kenetic heat to be consentrated in one area making the temperature peak quickly (which is how diesles run, but we are speaking of a 4strok gasoline engine) this temperature peak causes detonation which we all know is bad unless you plan on running 112 leaded fules.
when you lover that compession to say 8:1, naturally asperated you have 130psi pushing out and 15 pushing in and with that same 15psi you have 260pushing out and 15 pusing in, there is also less of a temperature peak and lower octane can be used or a more advanced timing can be ran.
now with a higher compression you have a greater thermal efficency but every engine has its limit and every fule has its resistance to detonation.
Old 09-15-2005, 08:16 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
When using lower compression pistons, you have more room to fit air in the combustion chamber as opposed to fitting it with metal. So more airflow=more horsepower. Less peak cylinder pressure=less torque.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 09-15-2005, 08:20 PM
CBFryman's Avatar
Banned
or you can get a super strong bottom end and head gasket and run high compression with high boost creating a flatter torque curve with the same top end power
Old 09-15-2005, 09:39 PM
240SX Guy
Not ultimately.
-Cory
12.6@122mph
Old 09-16-2005, 12:05 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Re: high compression vs. low compression on turbos
Originally Posted by CBFryman
think about it
that's a tall order for this guy
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-16-2005, 07:19 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
also on high comp high boost engines, you have to have the car tuned nearly perfect to avoid detonation.....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 09-16-2005, 10:05 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Here's a website that shows a chart of final compression ratio. Its a chart plotted with initial compression ratio on one side and psi on the other. Since street engines are limited by pump gas, your limited on how much pressure you can add before you're out of octane. When that happens; Kablooey.
http://www.goodvibesracing.com/Compression%20Ratio.htm
Dropping CR does not remove as much as a turbo gives back. As long as you don't drop below 8:1 or so, you won't notice sluggishness when the turbo is not spooled up, and depending on how well you tuned the turbo it will spool up almost instantly after you mash the pedal anyway.
Just dropping from 10:1 down to 8:1 you might lose 10% hp, but the 10-ish psi you can now blow will increase your power output by about 70%
Dragging people kicking and screaming into the enlightenment.
Old 09-16-2005, 10:12 PM
240SX Guy
READ on the knock limit!
-Cory
12.6@122mph
