Old 06-11-2009, 09:59 PM
lee32 lee32 is offline
1986-old low compression 305
Hey guys. I'm having trouble with a 305. I done a compression check on it today, because the power sucks, and i have 58-62 lbs on all cylinders. What do ya'll think is the problem? rings or cam? I had changed the cam a while back, but had to park it as soon as i done the cam change. So i don't remember what the compression was before the change. any info would help. THanks
Old 06-13-2009, 05:07 PM
777stickman 777stickman is offline
Re: 1986-old low compression 305
My 1st guess would be cam timing and/or rocker arm adjustments.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-13-2009, 07:01 PM
wafrederick wafrederick is offline
Banned
Do a leak down test also,there is a tester for this.You can make it yourself too.Do it to every cylinder with the spark plugs out,the engine on TDC.If air comes out the intake or out of the valve cover,intake valves or bad rings.Out of the exhaust,the exhaust valves.
Tags
305 , compression , low
