Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > General Discussion
General Discussion All general comments or enquiries go here. Website, club oriented, or general Skyline banter.
Old 12-25-2002, 05:45 AM
digsyHR31GTS-X digsyHR31GTS-X is offline
Unhappy higher rpm fuelling up + missing
my HR31 GTS-X with RB20DET running 10psi fuels up really bad after 4000rpm or so and u can even see black smoke pouring out the exhaust! When it does it u can certainly feel it, runs like a bag of crap!
Anyone with the same problem or any solutions would be greatly appreciated.
Also put flat to floor (in any gear, it's auto) and it revs the guts out of it and wont change gears until i back off???????
Old 12-25-2002, 07:51 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
When was the last time you changed the fluids in your auto?
"RB20DET running 10psi fuels up really bad after 4000rpm or so and u can even see black smoke pouring out the exhaust!"
I do not really understand? My Stang runs 40psi at idle, and about 90-100 under boost. Sounds like your fuel pump is going, your psi is not there at the higher rpm range.
Black smoke sounds like your turbo might be going as well. Just a guess, all your problems seem to be unrealated, meaning you got some work to do Good luck.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 12-25-2002, 01:02 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
I was under the impression that white smoke ment bad turbo
And what friggin supercharger are you using Tony?
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 12-25-2002, 05:51 PM
SkylineUSA's Avatar
Black smoke? Maybe your right. Black is normally based from an oil problem, at least that is what I remember. I could be mistaken. Do a little research, its getting late for me.
I am running a S-trim, 13lbs now.
Old 12-25-2002, 09:43 PM
sorry i meant 10psi boost up from factory. It's not white (indicating head gasket problem or blue indicating burning oil) it's black excess fuel being burnt. It just chokes up really bad and runs really rich. I've run carbon cleans through it, had the injectors checked + cleaned. I've even tryed heaps of fuel additives + cleaners. I've replaced just about every electrical conector on the injectors, TPS, coolant temp etc.
It's gotta be an engine management problem or maybe o2 sensor or AFM????
Old 12-26-2002, 12:19 AM
SkylineUSA's Avatar
You are absolutely right Black is Fuel, Blue is oil.
If your at WOT, o2 do not play. Have you cleaned your MAF?
Old 12-26-2002, 12:45 AM
SkylineUSA's Avatar
It's gotta be an engine management problem. I totally agree
Old 12-26-2002, 01:43 AM
Gonthrax's Avatar
Skyline Guy
Yes sky, engine managment for sure.
Try resetting your ECU for the hell of it too.
Neishlin Motors
Old 12-26-2002, 05:17 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
I doubt it would be the factory ECU as they are pretty primitave in the R30 and R31's.
If the car idles fine and is fine under normal driving conditions other than at WOT then the AFM will be ok.
Assuming your car is fairly standard here, what sort of spark plugs are you running? In the RB20DET you should be using NGK platinums part number PFR6A-11. Set the gap to .9 mm or .035 inch.
While your there check the carbon tips on the coil packs. Depending on which style you have there should be a spring with a carbon tip. If the spring is weak then the carbon tip will not make good contact with the plug. You can gentely shave it down to make it square again and good contact with the top of the plug. Which brings me to another thing. Be very careful removing them as the wires and coil packs themselves will be brittle.
Another thing to check is for any splits in your induction hoses or loose clamps. What could be happening is a boost leak, a small one will cause you grief. The AFM will be seeing more air than what will actually reach the engine causing an over fueling situation.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 12-26-2002, 06:36 PM
it had a very fast idle, but i fixed that by pulling my idle speed control motor out and where the little piston runs in the sleeve inside was worn and really sloppy hence letting too much air through. i fixed that by wrapping it with electrical tape, no just runs at base idle of around 600rpm and idles fine and doesn't stall.
Just recently it has a bit of a miss at idle every now & then, i've reset the ECU a few times now, but nothing every seems to help let alone the fuelling up
I have put new NGK platinum plugs in it but i didn't adjust the gap
Old 12-27-2002, 01:17 AM
SkylineUSA's Avatar
Did you check the gap, normally their in the ballpark, but you never know.
Old 12-27-2002, 03:37 AM
no, didn't check the gaps but the missing and fuelling up was there before replacing the plugs, the didn't make it any better or any worse
Old 12-27-2002, 03:51 AM
RazorGTR's Avatar
Skyline Man
It is sound more and more like a leak in your pluming or i/c. Spend some time and pull it all appart checking for cracks or splits.
Old 12-27-2002, 04:31 AM
SkylineUSA's Avatar
I guess using WD-40 will not show anything, looking for the leaks?
Old 12-28-2002, 02:47 PM
RazorGTR's Avatar
Skyline Man
It would if he could put the car on a dyno and do the checks, then so would soapy water but not sudzzy.
1995 Geo prizm misses at higher rpm Ficks Nova | Prizm | Spectrum | Sprint 0 01-18-2009 02:36 PM
My car starts hard and idles ruff at higher rpms 90Civ` '88 - '91 Civic | CRX | Wagon | Shuttlee 1 04-20-2004 02:51 PM
Car sputtering in higher rpms only?? JimCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-31-2004 05:50 PM
HIgher RPMS MXrider22 Engineering/ Technical 0 09-27-2003 12:25 PM
higher RPM fuelling up + missing digsyHR31GTS-X Performance 0 12-25-2002 05:32 AM
