Old 03-30-2004, 11:37 AM
JimCRX's Avatar
JimCRX JimCRX is offline
Question Car sputtering in higher rpms only??
Well just when I thought everything was running right on my CRX it came back again. I got a good feeling it's the distributor, I have a brand new one coming Friday, but I still would like to know what the problem is incase it isn't my dizzy. I was checking the cap out and I posted before that I discovered that my wires before they connect to the crank angle sensor plug were spliced and soldered together. I taped them up really good so they werent touching each other. My rotor is fairly new and the metal plate in the middle of the rotor is straight out burnt black and so is the coil. I figured it's normal cause it shoot electricity back and forth. Anyways, no matter how long I let my car warm up, I'll lay on the gas or not lay on it, but soon as it hits about 4,000rpms it'll start jerking and the rpm needle will fly around all the way to the redline even though I'm not redlining. I'm just guessing this cause the crank sensors sets the fuel timing doesn't it? I'm just guessing maybe it's sparking or sending fuel at the wrong time or either my dizzy internals are bad. Any idears?
Old 03-30-2004, 01:09 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: Car sputtering in higher rpms only??
Mine did that before, started at 5k, then 4k then 3k, turned out to be my coil, also check the connectors ont the ignition module, sometimes they come loose.
Old 03-30-2004, 07:16 PM
90civicracer's Avatar
90civicracer 90civicracer is offline
Send a message via AIM to 90civicracer
Exact thing happened to me. It was the distributor. I could go up to 3.5-4k rpm's and after that it was like a show the tach put on, moving up and down and up and down, it was crazy.
***90 Civic EX 4 Door***
Ace$nyper: yea it did woo woo 4500 posts i should be ashamed *kills self*
90civicracer: haha you killed yourself you got
Ace$nyper: OMFG LOL that might be the funniest thing you EVER posted
bwhahahaha
Old 03-31-2004, 03:22 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
I had the same trouble. At first, I replaced the rotor in the distributor. Then I replaced the coil.
Finally, I got another distributor and put my new coil and rotor in it. Fired up after some cranking.
Flunky
PS-And although this sounds totally wrong for a fuel-injected car, it had been sitting for a couple of weeks, and I had to hold the gas pedal down to get it to start the first time...
Old 03-31-2004, 05:50 PM
89stdzc 89stdzc is offline
Send a message via AIM to 89stdzc
i had a similar problem i replaced the dizzy and but still had the bogging at WOT so i fixed the TPS
