Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 12-22-2002, 11:40 PM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
H22A boost concerns
I just got a JDM H22A which has a cr of 10.6. I was planning to slap a cometic or rIDEAL head gasket on to drop the cr just under 10.0. Which that compression ratio, how much boost do you think I will be able to run on the stock internals max, without having to worry about my ring lands. I've been hearing bad things about H22 ring lands. Maybe the JDM ones are stronger....I hope
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 12-23-2002, 09:09 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
i still think that the internals of a h22a can only take a mix of 10psi with a cr of 10:1,
10:1 is still pretty high, i also heard that the piston rings will go with boost higher than 10psi,
i say go all out and do your internals , fuel, and ignition sys, then go and boost the h22a
Shift_BOOST
97 s14
Old 12-23-2002, 10:32 AM
del del is offline
móddə rąytər
you can fry the piston rings at even lower psi if your not tuned right.
10psi is definately pushing it. even 9psi is a stretch but some people do get away with boosting 9psi on stock internals.
just do it right the first time. too many people short cut their way to so much hp and they end up spendin more $$ than they could have if they did it right in the first place.
Old 12-23-2002, 12:48 PM
I only plan to use 6-7lbs of boost. I'll be using 4lbs daily. I am planning to get a MSD-BTM and FMAXs ERL-MF@, which is an additional injector controller. After the install, I plan to take it to the dyno for tuning. With all of the that, will I still have to worry about my ringlands? I am most concerned about them
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 12-23-2002, 12:53 PM
turbo2nr's Avatar
u should be fine
jus dont abuse da motor 2 much
6-7lbs should be fine in a h22a
just dont get excited n turn boost up
have fun
Shift_BOOST
97 s14
Old 12-23-2002, 12:55 PM
experience is key
Are there any turbo Prelude owners out there????? What's your insight?
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 12-24-2002, 07:30 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
yes, i have had a turbcharged 5th gen, and am currently rebuilding mine back up for turbo duty.
all i'll say is "be careful" and make sure your fuel is properly tuned.
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
Boosting an H22A mrsyeltzin Let's get Technical! 27 04-19-2004 05:46 PM
info on h22a buildup for high boost 8urdomestic Forced Induction 6 01-06-2004 10:00 AM
is the h23 block with h22a head a good foundation for 20psi of boost? >>>DOHC<<VTEC<<<< Forced Induction 4 10-20-2003 04:56 PM
Boost or no on a Accord with an H22A????? bigpimpingeo Forced Induction 7 04-28-2003 06:43 AM
