Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 04-24-2003, 10:20 PM
bigpimpingeo bigpimpingeo is offline
Send a message via AIM to bigpimpingeo
Question Boost or no on a Accord with an H22A?????
I'm thinking of buyinf an Accord. 2.2L. However, I'd want to put an H22A in it cause the Accord motors are junk. From what I've heard though H22A's don't respond well at all to boost. I've heard with a turbo they have about a 65% failure rate. Now I need to find out why that is.....
Is it the combustion chamber design or what? If so would lower compression pistons help or even just a thicker gasket... What??
Sorry this is so tough but it will be the deciding factor on whether or not purchase an Accord. Thanks...
Previous owner of the baddest ass Geo Prizm you'll ever see....
Old 04-25-2003, 02:04 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I am not an expert on Honda engines, but lower compression pistons is always a good idea with a turbo. Perhaps people are putting too much boost for the stock internals to handle, perhaps they aren't re-sleeving the engine. You can run higher compression on a turbo, but it takes VERY good engine management and a fair amount of tuning. You are better of lowering your compression, and don't use a thicker head gasket, lower c/r pistons is the right way to do it.
Also have you considered a B series engine?
Old 04-25-2003, 02:49 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
i'd get a b series..
the h22 shifts back and to the left when it revs while all other honda engines shift back and to the right when it revs. the prelude was designed to handle the shift of the h22, other cars arent... so if you are high revving while cornering you wont handle as well.. just a thought.
Old 04-26-2003, 04:33 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
dont put a b series in an accord. H22a, just dont run too much boost til you build it to handle it. lower the cr, forged internals, good tuning.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 04-26-2003, 07:05 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
is that why the Accord SiR from 1995-1997 came with the H22A in japan?
i'd like some proof of your statement, considering the H and B series motors all rotate the same direction and feature the same ignition sequence. it's also not the tranny or drive linkage since all current Honda motors feature two equal length CV axles combined with an intermediate shaft to correct the torque bias the older Hondas suffered with inequal length drive axles.
plus, the H and F series motors feature a forward motor mount for improved engine stability and support compared to B and D series motors.
it's due to two main things... the Prelude features very thin ring lands to prevent unburnt fuel from hiding from combustion. this was done to help meet US emission standards. these thin ring lands are fragile, and can break under heavy loading like that of forced induction.
also is the inclusion of FRM liners. FRM doesnt have as much tensile strength as ductile iron, thus limiting it's boost capability unless new sleeves are installed.
replacing the pistons with quality forged pistons a half point lower in compression will solve the ring land problem. sleeving the block with iron sleeves will solve the FRM problem.
putting a B series motor in your Accord will create the problem of "how the hell to mount the fucker" to the mounting positions... there are no mount kits for putting a B series motor into the bay of an F/H series equipped vehicle. you could do it with enough creativity, but why? losing over 30ft/lbs of torque will make you pretty sluggish off the line considering your chassis weight, and losing power is not really the idea of the game, is it?
Old 04-27-2003, 12:41 AM
strodda strodda is offline
do jdm h22's have the same problems with the ringlands and frm liners? you mentioned they were that way because of US emission laws, but regulations are less restrictive in japan arent they?
Old 04-27-2003, 05:31 AM
ljrlude01 ljrlude01 is offline
Send a message via AIM to ljrlude01 Send a message via Yahoo to ljrlude01
get the H22a, I have a boosted prelude with stock internal for now and Is all about tunning. I seen afew guys running as high as 11PSI on H22A stock internal, not that I would try this. plus from what I hear the H22a drops right in the accord bay.
01 Boosted Prelude
90 Nissan Skyline GTR
Mi-4
"current projects"
92 Honda Prelude,Ballade CRX
"finish project"
Skyline R34 GTR
Old 04-28-2003, 06:43 AM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Couldnt have said that better!!! Drift your always on top of things!!
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
91 accord with h22a 94accordlx1 Accord/TSX/Accord Hybrid 1 09-01-2005 07:28 AM
WHEEL HOPS IN 93 ACCORD WITH H22A Please HELP mast0075 Accord/TSX/Accord Hybrid 6 03-14-2004 11:02 PM
is the h23 block with h22a head a good foundation for 20psi of boost? >>>DOHC<<VTEC<<<< Forced Induction 4 10-20-2003 04:56 PM
performance options for 4th gen accord with h22a swap whitadel Accord/TSX/Accord Hybrid 4 06-17-2003 07:00 PM
