Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-06-2004, 01:38 PM
mrsyeltzin's Avatar
mrsyeltzin mrsyeltzin is offline
Boosting an H22A
Im getting (hopefully it arrives soon) a JDM h22a for my 92 accord. I want to try to keep the compression at the stock 10.6:1 for power, and i was wondering how much i can safely boost with it. I dont really want to lower the compression because i want to keep the benefits of the high compression from that motor.
proud accord owner
Old 04-06-2004, 03:31 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Boosting an H22A
I'd say probably a max of 6psi if even that with stock compression. I wouldn't even try it if i were you.
Old 04-06-2004, 05:38 PM
mrsyeltzin's Avatar
I knew i wouldnt get much. What hp would 6 lbs gain?
proud accord owner
Old 04-06-2004, 05:41 PM
B1SiR6A's Avatar
B1SiR6A B1SiR6A is offline
Aren't there flaws in the H22A when it comes to bossting it?(weak walls etc)
"Check that young man for nitrous"
12.428 @ 92.5 Mph
Before, Now
12.000 @ 94.1 Mph
On 1000ft Track
Currently 4th in BHRA All Motor Class...Soon to be 2nd (I hope)
...Theres gonna be alotta slow singin, an flower bringin if I hear my car alarm start ringin ...
Old 04-06-2004, 05:56 PM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
Re: Re: Boosting an H22A
yeah, i would look into forged parts and resleeving it before anything. but since its only 6psi...maybe he'll be ok?
Old 04-06-2004, 08:59 PM
mrsyeltzin's Avatar
I was worried about weak pistons (didnt know about the sleeves), but if i were to get these stronger pistons and sleeves, could i boost at maybe 8-10 with the high compression. Right now its just a thought, but im trying to avoid lowering the compression. Just dont want to lose any natural motor power.
proud accord owner
Old 04-06-2004, 11:44 PM
liquidflame8 liquidflame8 is offline
you have thin cylinder walls. so sleeving = good idea
Old 04-07-2004, 12:23 AM
strodda strodda is offline
just curious, but do you have a turbo kit already or have a deal on one?? if youre still gonna be spending money, id say build it up and stay n/a. but thats just me, i prefer all motor.
Old 04-08-2004, 08:20 AM
mrsyeltzin's Avatar
No deals, but i wanted too explore some options. I really like the idea of all motor, but turbo can be hard to resist...
another question for you guys....i got offered a complete nitrous kit for 500, he said i could safely do 50 shots on the h22, but im skeptical. Whats a safe limitation?
proud accord owner
Old 04-08-2004, 08:27 AM
mrsyeltzin's Avatar
strodda, you have an h22 in your accord right?
proud accord owner
Old 04-08-2004, 11:38 AM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
h22a is a kick A$$ motor for N/A applications...They have weak cylinder walls and deck. you will need to sleeve the walls and deck it before you run any boost in there otherwise within a yr your gonna be out a brand new motor. As far as getting new pistons and keeping the same compression and raising the boost...that is a huge NO NO... if you are hell bent on boosting this plant and not lowering your compression, you need to get new pistons yes and new rods as well along with the cylinder sleeves and your still gonna be limited to 6psi MAX..I think you need to learn how a turbo works and makes its power before you explore this because you would then learn that a turbo cannot operate under high compression..you will DETONATE...If you wanan boost you need to lower your compression, if you want to leave your compression then forget the turbo idea ...it boils down to physics..YOU CANT HAVE BOTH ..you need to pic one bro, turbo or compression
Old 04-08-2004, 06:09 PM
mrsyeltzin's Avatar
roger that tranzlogic. your right i dont know shit about turbos. but thats why i posted this thread, to see what i can do. thanks for all the info.
proud accord owner
Old 04-09-2004, 11:38 AM
not a problom man, after all thats what all of us are here for...Q and A and sharing matters of opinions.
Old 04-10-2004, 12:48 PM
boosted331 boosted331 is offline
If you sleeve the motor and drop the compression to 8.5:1 or 9:1 you will still make more low end torque than any naturally aspirated B16 or B18 would, so why are you so stuck up on keeping 10.6:1? You may only make another 15 horsepower naturally aspirated, but going to 8.5:1 may allow you to run another 12 pounds of boost on pump gas, and making a ton more top end power. Besides, how much racing do you do before your turbo spools? First gear, then you shift, then you never fall out of boost and if you had high compression that's when you would be wishing you had low compression so you could run more boost and power.
Old 04-10-2004, 10:44 PM
mrsyeltzin's Avatar
so would a turbo also increase my torque at about the same ratio it increases h.p?
proud accord owner
What needs to be done to an H22a internally to make it boost safely? preludeguy017 JDM Motor & Parts info/chat 1 06-02-2010 01:28 AM
info on h22a buildup for high boost 8urdomestic Forced Induction 6 01-06-2004 10:00 AM
is the h23 block with h22a head a good foundation for 20psi of boost? >>>DOHC<<VTEC<<<< Forced Induction 4 10-20-2003 04:56 PM
Boost or no on a Accord with an H22A????? bigpimpingeo Forced Induction 7 04-28-2003 06:43 AM
H22A boost concerns dominate9 Prelude 6 12-24-2002 07:30 AM
