Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-18-2003, 03:24 PM
8urdomestic 8urdomestic is offline
Question info on h22a buildup for high boost
Ok am building my h22a for high boost like 15-20psi.
well here is my setup:
RevHard Turbo T3T4 with .54trim
RevHard Turbo Manifold
Turbonetics External Deltagate
PWR 31x11x3 Intercooler
Turbo XS RFL BOV
Missing Link
MSD Digital 6 Plus
V-AFC
AVC-R
ACT Clutch Set
Darton replacement Flanged sleeves
JE Pistons 9:1 ratio
H-Beem Eagle Rods
AEM Cam Gears
AEM Fuel Rail
AEM adjustable FPR
72LB injectors(756cc)
EVO CatBack exhaust.
well thats all i have as of this moment so if you guys can tell me what else i need i would love it.oh and am also going to spray around 100-150 shot of NOS.so what else do i need to upgrade?
Thanks in advance for all positive info.
Old 11-18-2003, 05:30 PM
boosted331 boosted331 is offline
You want to run 20 pounds of boost, and a 150 shot of nitrous on your prelude with a V-AFC, a missing link, 720 CC injectors and your stock fuel pump. Are you on fucking crack or is this supposed to be some kind of a dumb joke?
Old 01-04-2004, 01:43 AM
silky4u's Avatar
silky4u silky4u is offline
Re: info on h22a buildup for high boost
maybe this is just me but i have heard and read quit a bit of stuff about how how boost sucks for the h22. Due to the larger bore less head gasket is present between cylinders and under high boost this small area can fail, resulting in the utmost of unfun.
I hate ALL people!
Old 01-04-2004, 02:46 AM
teglsturbo teglsturbo is offline
Are you getting a new motor or something. Why are you in such a rush to kill your engine. 20psi on almost all stock internals...on a h22a... you're crazy. But oh well do what you will, its your engine. Do a search there are plenty of posts that will help you with your question.
Old 01-04-2004, 11:10 AM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
He said he was building it. Pistons, rods, and a sleeved block (especially for an h22a) is sufficient to run 20 psi. Yes you are missing a high flow fuel pump off the list. You need to run at least an 255lph pump. Also as stated before, ditch the missing link and AFC setup. That is just fine for low boost, but you won't get far with 20psi on a AFC hack.
Old 01-05-2004, 05:14 PM
boosted_88_CRX boosted_88_CRX is offline
BLOCK GRAD
u can get up to 10 PSI with that
thats all u need
Old 01-06-2004, 10:00 AM
Re: Re: info on h22a buildup for high boost
Originally Posted by boosted_88_CRX
BLOCK GRAD
thats all u need
I assume you are referring to a block guard. He states he wants to run 15-20 psi, not 10 psi. Everyone that I know that has had a block guard has had cooling problems. If you are going to boost 20 psi, you can't go cheap on it. That is how motors get blown.
