Old 11-24-2002, 02:21 PM
custom86Lx-i custom86Lx-i is offline
need help with my B16A
i bought a pr3 ecu with a spoon chip and my car wont start all it does is throw a code 15 and i have an MSD cap with an accel external coil. what should i check or mess with to get it started or do u think it is the ECU
thanx
AJ:bandit:
Interior:
gutted except the dash , painted with a
truck bed liner , carbon fiber shifter, E-Brake handle and pedals
Exterior:
none yet but stripped mouldings and black steel rims.
Performance:
B16A swap, Cam Gears, race spec pulley (no accesories), ACTstageIIclutch, CTR valve cover, DCsport 4-1 one piece headers, Magnecor race wires, NGK plugs
crane distributor upgrade, MSD 6A ignition, Custom intake with K&N filter
,Custom Ram air, New radiator, new stock fuel pump with a HOLLEY in-line, AEM FuelRail with B&M Regulator, Accel 30Lb injectors, 75 shot N2O, MUGEN ECU chip
Suspension:
Tokico blues with sprint 2.25" springs
lude A-arms "camber kit" in front
ingalls rear camber kit in back
no strut bars yet
no wheels
Old 11-24-2002, 02:25 PM
and my 6A ignition was sold amd my mugen chipped ecu got fried just in case any body cared
Interior:
Exterior:
Performance:
Suspension:
no strut bars yet
no wheels
Old 11-24-2002, 03:04 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
what is a code 15 ? if you can get another pr3 from a friend of your or something then try swap in a stock ecu too see if it is the ecu.
Old 04-04-2003, 02:58 PM
94delsolSI 94delsolSI is offline
just go to shop and find out what code 15 is and then you'll know what the problem is
need help swaping b16a obd0 into 93 honda del sol boy704 How-To's and Walk-Through's 0 09-28-2007 12:33 AM
need help on b16a J-Spec ideling jeremiah.k '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-25-2005 08:32 PM
Need help with turbo cams for b16a gen-I civicfreak1 Let's get Technical! 1 03-29-2005 04:37 PM
Help with b16a 96civicberk '96-'00 Civic 12 03-28-2005 08:54 PM
need help with emissions b16a 1 civicHatch '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-13-2004 05:36 PM
