Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-01-2002, 09:54 PM
LjasonL's Avatar
LjasonL LjasonL is offline
Some Guy
Send a message via AIM to LjasonL
gts ?'s
okay im thinking about buying this old gts i found. not sure on the year model yet, gonna go check it out more completely tomorrow, but its the ae86 style. so heres my questions.
1. the later versions of the 4age had a higher compression right? so can i swap the rotating assembly from one of those directly into the earlier 4age for higher compression?
2. i want fuel injection. is it possible to get the top end and ecu from a newer model and convert it into FI?
thanks in advance...
Old 11-01-2002, 10:56 PM
Lafora Lafora is offline
Re: gts ?'s
blocks are compatible. heads aren't unless you have an adapter that'll take the intake assembly and face it the correct way.
no 4AGs run carbs from the factory, they are all FI. i am not exactly sure what you were trying ot get at for quesiton number 2.
Old 11-01-2002, 11:28 PM
LjasonL's Avatar
Some Guy
damn my bad, i thought some of them were carbureted. dont i feel stupid
thanks for the help
Old 11-01-2002, 11:39 PM
LjasonL's Avatar
Some Guy
any idea what year i should be looking for to get the higher compression stuff?
Old 11-01-2002, 11:41 PM
it's real easy
if you see TVIS, it's not a small port.
all 4AGs running TVIS are big port 4AGs. BUT the zenki AE92s have big ports AND 7 rib blocks.
ALL AE86es have big ports with 3 rib blocks.
Oil capacity of GTS rear axle 2006GTS GTRA / GTWS / GTS 2 10-01-2010 07:46 PM
GTS car for sale coach0187 GTRA / GTWS / GTS 3 04-07-2009 09:32 PM
GTS to GTS-T cam conversion? raptor Performance 20 01-01-2006 07:25 AM
HELP GTS or GTS coupe or sr5 ImportedCARZ Corolla/Matrix/Voltz 11 03-10-2004 09:42 AM
+'s and -'s of aftermarket cam gear and installation civicex23 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 09-10-2003 05:38 AM
