Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 10-01-2010, 06:05 PM
2006GTS 2006GTS is offline
Oil capacity of GTS rear axle
I had to remove the 9 inch differential assembly from the rear axle of my GTS to re-seal the interface to the axle housing because it was leaking oil. Upon reassembly, I realized that there is no oil fill level hole in the housing or carrier. I can fill it at the top of the housing by removing the return line from the oil cooler. I asked a local race axle specialist how much oil to put in, and was told 4 quarts, but I think this is going to fill the axle housing above the level of the axle tubes, and I am wondering if this is too full and a lot of oil is going to come out the breather when we run it on the track. Can anyone tell me how to get the proper oil level in a GTS axle? It has the Tex racing differential with integral oil pump and seals that block off the axle tubes near the center section.
Old 10-01-2010, 07:32 PM
eric1h eric1h is offline
Re: Oil capacity of GTS rear axle
3 quarts
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 10-01-2010, 07:46 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
isn't it more like 2.87 -- mine did not take all 3 quarts.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Frnt/Rear Axil Oil Capacities? jumpingjack66 Silverado 7 06-05-2006 03:55 PM
03 Trailblazer Rear Axle Oil Change lizplusthree TrailBlazer | Trailblazer EXT 1 08-07-2005 08:28 PM
Rear Axle Oil Seal pnoiSR20 Tacoma 3 07-07-2004 11:29 PM
Tags
axle , capacity , gts , oil , rear
