Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-20-2002, 05:26 PM
zskta06 zskta06 is offline
intake
i was just wondering what the difference was between the aem short ram and the cold air intake. which one has more hp or other advantages?
Old 10-21-2002, 06:17 PM
97gsr's Avatar
97gsr 97gsr is offline
Send a message via AIM to 97gsr
i would imagine that the cold air make a few more horse...
I am currently trying make the same decision!
Do i really wanna disassemble the front of my car in order to get the air filter located where it needs to be?...NOT REALLY...
so i think im just gonna buy the short ram...
ANYONE ELSE HAVE ANY INPUT?...please help us make our decision!!
Thanks
peace
Old 10-23-2002, 01:05 AM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
sup guys i've put them both on gsr's and ls's
the short ram has a good filter.. but sux engine air.
the cai sux the air from under the bumper for colder air.. more power..
i know it seems like a pain but it is really easy to do..
besides.. it's well worth it and the cai sound sweet as all hell..
S2000
Old 10-23-2002, 10:20 AM
shocky shocky is offline
Send a message via ICQ to shocky Send a message via MSN to shocky
Does anybody has the instructions to install a COLD AIR SYSTEM in the Integra with photos or a "HOW TO" web page ??
94 Acura Integra 4 Door, JDM Si-R II B16A 5.4Million Series Engine Swap (170HP Stock), With CTR Camshafts, STR Camgears, Clutch Masters Stage 4, DC Sport Ceramic Header 4-2-1, Exhaust System 2.25" W/Apex-i N1 Cat-Back, AEM Cold Air Intake, ECU Erick Racing 5,800rpm Vtec, B&M Fuel Pressure Regulator, Y21 Code GearBox, 16" Rims W/Yokohama Avs Sports. It's not much but I still can smoke fools. Oh Yeah and Don't forget, I'm Proud Member of Guatemala Streetracing. http://www.gtstreetracing.com
Old 10-24-2002, 07:40 AM
THE4TH's Avatar
it's easy..
which system did you get???
if it's the aem the directions kinda suck..
but if it's something else, then ya should basically take the exisiting air box out.. and take off the air tube that runs to the throttle body..
then take your new intake.. and put the filter on .. then there should be some support with it.. although some do not.. and then attach the other end to the throttle body..
tie everything down and make sure it's sealed.. and everything is plugged in ..
and before you do anything .. remove the negative terminal from the battery.. it'll reset the air sensor to get better readings.. make sure it's off for at least 15 min..
then turn her over and let the sucking begin..
S2000
Old 10-24-2002, 09:51 AM
97gsr's Avatar
on my 90 teg, the filter for the cai needed to be placed directly where there was a stock resonator box for the OEM air intake...
it was a bitch to remove...
is it gonna be the same on the 97 gsr?
Is this same type of box there?...and what do i disassemble to get to it to remove it?
Thanks!
Old 10-24-2002, 10:08 AM
Originally posted by THE4TH
it's easy..
if it's the aem the directions kinda suck.. ..
Yes i got that system!! and it's not a shot ram and it's pretty dificult to install because the air filter doesnt fit between the chassis and the bumper.
What do i have to do to fix mi problem? Do i have to buy a smaller filter??
Old 10-25-2002, 12:53 AM
THE4TH's Avatar
you have to remove the resonator..
and a few other random plastic parts..
the stock filter should fit.. but for some reason if it does not..
then you could get a filter that will fit.. or perhaps cut some of your wheel gaurds to make it fit..
S2000
Old 10-25-2002, 03:05 AM
york2600 york2600 is offline
Send a message via AIM to york2600
A few things on short ram via CAI
A) Cold air gets better HP because even though air flows through the engine bay the air outside is still several degrees cooler. Cooler air has more O2 molecules.
B) You can install a CAI without taking off the bumper. You just have to leave in the water reservoir (it's in a pain in the ass place to get too). If you really think about it to install a short ram intake you're leaving this box in anyways. If you want to drop like 1/2 a pound then you can pull the bumper off. I did it broke a plastic retainer. Total pain. Don't bother
C) Cold air intake gets dirty. Dirty CAI = less HP than a short RAM. You have to clean the thing sometimes. K&N sells some cleaner stuff. I've never used it. It may be a total gimmick.
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
Old 10-25-2002, 12:52 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Re: A few things on short ram via CAI
Too bad we didnt know that the first time around :hehe:
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 10-30-2002, 09:02 AM
schae schae is offline
i like the bomb cold air intakes....its not all that expensive either
http://www.speedstash.com/coldair.html
cold air intake created by using an intake pipe and a stock intake tube is this OK civic95 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 06-22-2004 02:04 AM
Stillen Intake/JWT Intake CharlieDigital Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 13 01-07-2004 12:01 PM
cheap intake plus ceramic paint = cheap good intake ? 96LSIntegraRocket Integra 4 04-06-2002 04:07 PM
Try This Out!!! Modify Your Stock Intake To A Cold Air Intake W/o The Pipe! cliffud Engine 7 02-27-2002 09:48 PM
I want Intake, JWT Pop has pipe or no? I want pipe, any Intake I can get with it?? DJ Hotpokit Engine 2 10-28-2001 09:27 AM
