Old 09-23-2002, 04:13 PM
454Casull 454Casull is offline
Why can't clutches be placed between the transmission and the differential?
Is there a reason why clutches are in front of a transmission and not behind?
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 09-23-2002, 05:09 PM
V.S. V.S. is offline
If there was no clutch seperating the transmission and the engine, then the gears would get grinded every time they were shifted. Or so I assume.
Old 09-25-2002, 01:16 AM
ales's Avatar
ales ales is offline
Forza Schumacher
You are absolutely correct. The reason there is a clutch is basically to be able to shift gears, and in order to do that (on a working engine) transmission has to be disconnected from the engine. hence the placement.
Old 09-25-2002, 06:15 PM
Whitebread Whitebread is offline
What about a sequential? (Is that even the right name?) Those trannies are manual but don't use a stick or a clutch, you just pull a lever or something equavilent, to change gears. They don't use torque converters, right? If so, then how do they change gears?
Old 09-25-2002, 11:50 PM
ales's Avatar
Forza Schumacher
Sequential is not quite the same as semi-automatic. What you are talking about is the latter. Those have very complicated electronically controlled hydrolic systems that do disengage the clutch and change gears in a matter of fractions of a second. Apart from F1 and Rally, the most successful versions are found on Ferraris and latest BMW models. Basically there still is a clutch, but it is operated automatically. I think the car might even double-clutch on downshifts. Can be wrong here. And another good thing is that with newer semi-automatic gearshift systems you don't even need to take your foot off the gas - the engine power is auomatically cut off for the split second that the gearchange takes place. As for just sequential gearboxes, if they are not semi-automatic, they still require a manual (errrm ... I mean normal - operated by foot ) clutch. E.g. Quaife makes sequential gearboxes that can be adapted to any car.
Old 09-26-2002, 04:30 AM
Gasoline Fumes Gasoline Fumes is offline
I don't see how the location of the clutch would effect shifting. As long as one of the shafts can spin freely, the synchros should work fine. One problem I see is the clutch would need to be much stronger, since transmissions multiply torque. Also you would still need the normal flywheel on the engine, plus another spinning disk for the clutch to grip.
And not all sequential trannies need to have the clutch disengaged to shift.
My Website
Old 09-26-2002, 08:11 AM
Ok, I understand now. Thanks
Old 10-02-2002, 01:29 PM
TheMan5952 TheMan5952 is offline
Volvo Guy
Send a message via AIM to TheMan5952
some differentals have clutches in them to lock both wheels together to gain traction.
Thought i would add that.
-Joe- '02 Volvo S60 T5
Sold!1993 volvo 850
Intake, Exhaust, Springs, Shock, I.C.E.
whats the difference between the 4t40e and the 4t60e aptyk88 Grand AM 1 01-13-2008 05:34 PM
what is the difference between the D150 and the W150 doggfather69 Ram Pickup | Ram SRT10 5 06-08-2005 07:02 PM
What is the difference between the ka24e and the ka24de engines? SubaruImprezaYM 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 8 12-19-2004 06:30 PM
whats the difference between the ecu and the eprom? BlackShadowTSi Off-Topic 11 06-15-2004 01:23 PM
soob noob...any major differences between the L and the GT? jackacc Legacy / Liberty / Baja 4 01-07-2004 10:05 PM
