Old 06-14-2004, 05:02 PM
BlackShadowTSi BlackShadowTSi is offline
Send a message via AIM to BlackShadowTSi Send a message via MSN to BlackShadowTSi Send a message via Yahoo to BlackShadowTSi
whats the difference between the ecu and the eprom?
I have the two of them i gues cause i have a 98 tsi awd engine and a 95 gs-t engine the both of them with the complete computer managemet, so like i put in the other post i was wondering to make the swap and i need to know the difference between them, thanks
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Check My GS-T ==> AWD project
car's video: http://cssteam.com/gstx.wmv
At the track: http://videos.streetfire.net/video/aad4c670-6066-44d5-b6f6-c04346cb8407.htm
Old 06-14-2004, 05:06 PM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
Re: whats the difference between the ecu and the eprom?
eprom is a type of ecu that's configurable by using dsmlink. they come in 95 gst/gsx only (i believe). regular ecus can't.
06 Charger SRT-8 black.
Old 06-14-2004, 05:15 PM
so the eprom is better, but basicaly have the same conectors and everything doesn't matters if the tranny is awd or fwd, cause i have the body and engine of a gs-t but the engine needs work, and in the other hand i have the engine of a tsi awd that i totaled but the engine is perfect with a 16g turbo on it, with the eprom and everything, i was asking in the other post what difficult is to make the swap and put the tsi engine in the gs-t body and keep the fwd tranny?
and other thing, i had the 16g on the tsi, but was there when i bought the car so i don't know if the last owner change the inyector, the fuel pump or something, and don't know if i have to change something of that if dicide to keep the gs-t with the original engine and put the 16g cause i know that the gs-t engine only have 1 mod and is the head it have the 1g head on it.
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 06-14-2004, 06:54 PM
slow down homie!! i can't digest! eprom IS better because you can hook it up and tune it directly with dsmlink to you laptop like you see in FF1. it ONLY comes with 95 gst/gsx, therefore, FWD/AWD. you need to check the injectors and fine out what they are before you do any tunning. same as fuel pump. inproper tunning can cause damage. you have a 98tsi, thus i don't think it's a eprom. altho, you can buy one and swap it.
Old 06-15-2004, 01:28 AM
so the ecu that is on my 95 gs-t is an eprom? right that is what you said? so is better to keep the ecu of the 95 gs-t. and about the injectors and the fuel pump, the tsi awd had the 16g installed when i bought it so i guess and i'm just guessing cause i didn't check that if was necesary to make that change the last owner made it, cause he spend a lot of money puting all good brands on the car (like greddy, etc), but otherwise the check engine light was allmost all the time on and that could be for a bad fuel managment i think. so maybe he put the turbo and he just not change nothin. ok let me know what you think.
but to be sure, if I want to put the 16g i must change the fuel pump and the injectors, i have a friend who have a set of inyector 440cc and a fuel pump, he told me that with that inyectors and fuel pump and my turbo i will be pushing 280hp at least.
he is asking 100 for the fuel pump i don't know how much for the inyectors, is that a good price?. thanks again for your time
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 06-15-2004, 01:32 AM
Question Re: whats the difference between the ecu and the eprom?
as you can see and i'm not from US and my english is not perfect at all , so i'm trying to do my best with the lenguage and with the car too, to make run as good as i can
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 06-15-2004, 01:47 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
All ECU's have a PROM chip. Some ECU's (like in some 1995's) have an EPROM which stands for Erasable Programmable Read Only Memory. It means that it's more versatile in a way, and it's necessary for DSMlink.
Old 06-15-2004, 02:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
As much as I hate when people use bad grammar and spelling, and generally abuse the english language, its ok when its not your first language My wife is brazilian, and I'm really good and decoding broken english Dont worry about it
JoeWagon hit the nail on the head for the eprom issue. All ECUs do the same thing, but the eprom ECUs have the "intructions" for the ECU on a chip that can be reprogrammed easily. So TMO, Jeff O, DSMlink, etc can change the code and therefore affect the way the car runs, to our advantage. Like I said in the other thread, use the EPROM ECU if you have one. All EPROM ECUs are 95s, but not all 95 ECUs are EPROM
Its hard to say whats been done for the fuel system. Stock injectors are 440s (so dont buy 440s!), and usually have a black top. RC 550s are common, and say RC on the side of them. All FIC injectors have the size engraved on the side of the body. Yellow tops are typically 510s, and blue tops can be one type of denso 660 (the good type). The pump is tougher. You can use the vfaq (www.vfaq.com) to pull it out and check the part number against RREs page (www.roadraceengineering.com). OF course, it would be much easier if you could get a hld of the previos owner
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 06-15-2004, 02:28 AM
95 GSXracer thanks for your patience, i will ask my friend tomorrow about the ineyectors but i'm almost sure that he said 440cc, he works in a place called Pacific Performance and they do a lot of race cars, almost all of them Civics, and they are plenty of parts that they take out of eclipse that were upgraded may be i can find something cheap.
About the inyectors they are black and looks pretty small, tomorrow maybe i will take them off the tsi engine to check whats the problem with the gs-t cause 1 of the inyectors is not working and this guy told me thats the only problem with the gs-t engine what means a lot of less work (swap the engine is pretty hard)
Diego Fontán
Eclipse GS-t ==>AWD
12.12 @ 113.xxmph
60' 1.76
Old 06-15-2004, 08:52 AM
as for your question about the pricing. yes $100 is a reasonable price. not too expensive but not too generous either.
Old 06-15-2004, 10:24 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
You can get a new pump for under 100
For Sale 98 Eclipse GS, 5 spd
Old 06-15-2004, 01:23 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Yea, you can get a brand new Walbro fuel pump from Dejon for $99.
