Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-22-2002, 06:46 PM
Aboverim16 Aboverim16 is offline
Cool Quicker spooling...
My uncle has a turbo deisle truck.... he had his buddy put a BOV on it and his buddy drilled a hole in an elbow joint and stuck it in the middle somewhere, this changed the vacum and now his turbo spools up around 1000 RPM. Is there a way I can make this same effect happen in an import car?... i dunno, if anyone knows how to make a turbo spool quicker then let me know.
thanks
Old 09-22-2002, 07:27 PM
chad174 chad174 is offline
sure, a 50 shot of nitrous would help it spool better the reason it worked on his truck is because he didn't even have a BOV before and now he added one. in an import car, chances are that it already has a BOV.
Old 09-25-2002, 01:20 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
Adding nitrous doesn't REALLY make the turbo spool quicker...It does to an extent, but what it really helps do is to get the RPMs into the range where the turbo spools, more quickly.
Another reason that worked is because the truck puts out a TON more exhaust than your car probably does, and trucks often use low-spooling turbo's to help with low-end torque, which is very useful in pulling power.
There's no replacement for displacement...No, not even a turbo.
spool up too quik... is that possible? MXrider22 Forced Induction 10 10-22-2003 06:31 AM
does boost effect turbo spool-up time? iceiso Forced Induction 21 05-25-2003 11:14 PM
turbo spool 4thgenlude Forced Induction 9 04-14-2003 10:39 AM
turbo spooling natedogs911 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 2 11-05-2002 09:13 PM
bov return hose to spool turbo? hondatool Forced Induction 8 10-11-2002 02:50 PM
