| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
does boost effect turbo spool-up time?
i know i posted this SOMEWHERE but i can't find it. thanks for replies!
A turbo takes longer to get to higher PSI's, so if your definition of spool time is the time it takes to achieve full pressure-then yes is the answer to your question.
what about the same amount of pressure. ie...
low boost-(2 psi, 2k rpm) (4 psi, 2.5k rpm) (6 psi, 3k rpm) high boost- (2 psi, 2k rpm) (4 psi, 2.5k rpm) (6 psi, 3k rpm) (10 psi, 3.5k rpm) (12 psi 4k rpm) is that what it is? they take the same amount of time to boost to the same RPM but it takes longer to get to full rpm on higher boost? |
Like what you said (2PSI@2K RPM, 4 [email protected] RPM etc) With only running a Wastegate set at 6 PSI it will stop providing more boost than 6 at 3K RPM (going by your chart you made) and will stay at 6 PSI even with more RPM. If set at 10 PSI it will stop at 4K RPM and not go any higher with more RPM, but it take 4K RPM to achieve 10 PSI. I hope this makes sense to you, if not just say so. |
right, i think i get it. alright, so to clarify...
true/false-up until the time that low boost stops increasing, high and low boost make the same amount of boost at the same RPM. THEN, high boost keeps on increasing. so, pretty much, high boost just increases for LONGER. |
Now you got it!
hahaha, aight, thanks for helping me out. since it looks like you know your stuff, i'm gonna ask another question instead of starting another thread, maybe it's relevant?
why do people say that t3/t4 is useless between 6-10 psi? |
Well the T3/T4 turbo is pretty big for a 4 cylinder. And 6-10 PSI is not very much boost. So you would be better off getting a smaller turbo like a T28 that will spool quicker and give you more boost at lower RPM's. Like a T28 will run out of steam at like 15 PSI, so if you want more than that you need to step up to a bigger turbine housing that will be able to pump more air. The T3/T4 is not useless, it's just not logical or necessary to use for such low boost.
how do the turbo #s work.. i dont get it.
t72 is huge? t3/4 is too big for a 4 cylinder? t28 is small? shouldnt it follow in order? |
also, another kinda irrelevant question...
i'm traveling 75 @ 3000 RPM on 5th i'm traveling 10 @ 3000 RPM on 1st which uses more gas? does speed/gear have an effect or does only RPM? |
T3/T4 is not to big for a 4 cylinder, it's just not justifyable to use for low boost applications because it takes longer to spool up as apposed to a T25 or T28. |
what everyone has to realize is that size and quality of ALL of your parts make spool up and psi different. my ball bearing 61 (equivilant) with my equal length manifold spools 10 psi before 4000. its because its ball bearing and i have the best flowing street manifold ever built. if you run a shitty manifold that effects your spool-up. what u also have to remember is that 10 psi on a t25 isnt the same as 10 psi on a y2k or a t61. take a look at some flow charts from the turbonetics webpage
![]() ![]() ![]() 6.7 @ 211mph whooping kubo's ass all over the track |
