Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-21-2003, 05:25 PM
MXrider22 MXrider22 is offline
spool up too quik... is that possible?
I have an H23... slightly larger motor but not huge... if i ran .48 exhaust housing on a 57trim .60 compressor housing T3/To4e turbo... i think it would spool faster do to smaller exhaust ar (but correct me if im wrong) but would it spool too fast... ??? i meen... the problem is a H23 will only safely rev to around 6300-6500rpm... which meens i dont want boost to start at 4300-4500rpm and reach full boost at 5000 and then shift half a second later... i want full boost (only runnin 6psi keep in mind) around 3500-4000rpm(no higher please)... is .48 #1 too resricting and #2 spool tooo fast... or would .63 be sufficient although i dont want boost so damn late in the range its owrthless to me .. thanx
Old 10-21-2003, 05:35 PM
SleeperCivic SleeperCivic is offline
You shouldn't have a problem. My friend has a Garrett T3/T04 on a B18C with lowered compression and it spools NICELY. http://civic.ibadesigns.com
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 10-21-2003, 05:36 PM
Re: spool up too quik... is that possible?
Also, it doesn't matter if you spool too quickly but if you can hold boost througout the rpm range. Fast spool = fast times.
Old 10-21-2003, 05:39 PM
well
well would a .48 hold boost through 6500rpm on an H23?
Old 10-21-2003, 05:52 PM
boosted331 boosted331 is offline
Re: Re: spool up too quik... is that possible?
Yes you can have too quick spool, a turbo that spools to quick will just blow the tires away in first and second on the street or the track. I'm thankful that my SC61 lags to around 5000, even then it's easy to spin hard if i'm on the highway doing 70 and I drop it down to third.
And yes a .48 A/R housing will hold boost to 6500 on an H22.
Old 10-21-2003, 06:04 PM
Re: Re: Re: spool up too quik... is that possible?
[quote=boosted331]Yes you can have too quick spool, a turbo that spools to quick will just blow the tires away in first and second on the street or the track.QUOTE]
Yeah, if he's running a lot of boost but he's only running 6psi. He's not going to make that much power.
Old 10-21-2003, 07:34 PM
hmm
well since it will hold boost through 6500rpm on an H23 (h22 same dif except vtech compression pistons and stroke) and im runnin low boost (so too fast spool isnt a big problem) will the .48 restrict horsepower? if i ran the same turbo with a .63 ar when would i see full boost... and if ran both turbos at same psi same rpms... would the .63 make more power... alot more power? another thing... if it spools so damn quik... and i end up in boost while doing like highway driving... is that a really bad thing?
Old 10-21-2003, 10:17 PM
Re: hmm
you will make more power with the .63 housing but the difference will be minimal, but you would get a bit more lag with the .63 A/R housing. If you're driving on the highway part throttle you won't make boost becuase there is no load on the motor, load produces exhaust heat and exhaust heat spools the turbo.
Old 10-21-2003, 10:20 PM
Re: hmm
A lot depends on the compressor side of the turbo and the piping. The larger the piping going from the turbo to the FMIC to the throttle body, the larger the HP gains. Air flow is the key to gaining power. You might have a T3, but if you have 2" piping, it's going to drop off on the HP and TQ curve really quick.
Old 10-21-2003, 11:06 PM
example
T3/To4e... specs are stage 3 wheel .48 ar(exhaust) ... and To4e housing compressor specs .60ar 57trim well assume 2.5inch piping(thats about average right?) from turbo to intercooler and intercooler to tb... now would i make enough power (230whp 6-7psi) with the .48 exhaust housing and would it spool fairely quikly?
Old 10-22-2003, 06:31 AM
Re: example
You should start spooling about 3-3.5k and be fully spooled at 6psi by 5k.
