Old 08-25-2002, 08:52 PM
dx_tuner's Avatar
dx_tuner dx_tuner is offline
Question New!!! ECU CODE 4 (crank angle sensor)
Hi I'm new to this forum, I drive a 89 Honda Civic DX HB, its still all stock. But I got a Janspeed universal muffler(got off of Ebay) I'm gonna put on it, is a 2.25in pipe a good size or should i go to a 2.5 in exhaust pipe? But anyways My car is throwing a Code 4 crank angle sensor and this really sucks cause when the chek engine light comes on I can't rev past 4000rpm and my car losses a lot of power. Does any one know how to fix this I'm totaly stumped :help:
1989 Honda Civic HB DOHC VTEC 1.8L 07 2005
WWW.HONDA-TECH.COM
Old 08-25-2002, 09:39 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
You'll probably want to check the connection to, or replace the crank angle sensor.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-25-2002, 09:41 PM
EF9JDM EF9JDM is offline
Send a message via AIM to EF9JDM
u had the same code a few weeks ago
I had to replace my Dist. that fixd the problem
90 civic si
<Keep It Simple Stupid>
Old 08-25-2002, 10:38 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i got that code when i had the wrong distro. & ecu. so, i agree with EF9JDM...sounds like your distributor is going bad
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-26-2002, 06:05 PM
dx_tuner's Avatar
finaly a forum that actually knows their 88-91 Civic/CRX
I thought it would be that dam dist. oh well at least it still has warranty
WWW.HONDA-TECH.COM
Old 08-26-2002, 06:34 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I had that problem with my Jeep Cherokee, and it was just the connection... I would certainly check that before replacing your dizzy...
Old 05-24-2004, 07:43 PM
d3rdcoastb d3rdcoastb is offline
Where???
where are the wires to tap into the CKP from the ecu?
I did a zc sohc swap and cannot find the wires // all instructions have me lost. I'm using DX distributor does that matter??
Old 05-24-2004, 07:48 PM
travagliante's Avatar
travagliante travagliante is offline
Re: New!!! ECU CODE 4 (crank angle sensor)
UM YES!!!
The dx distributor is for DPFI and didnt you convert to MPFI. You have to get the sohc zc or a d16a6 distributor(obd0) for it to work!
Oh and please dont bring 2.5+ yr old posts back, just make a new topic
Old 05-24-2004, 07:57 PM
I'm very sorry
I did create a new post but then found this one on the search function and had a new idea because I am really frustrated at the wiring//some say it doesn't matter i just have to find the wires to do it and now i'm hearing i need different dist entirely so the new dist will have the blu/grn an blu/yel wires to connect to from my c1 and c2 wires i ran??
Old 05-24-2004, 08:17 PM
yes, a dx distributor lacks 2 wires. A mpfi distributor has 2 more wires. 2 more wires 2 more fuel injectors.
Old 05-24-2004, 09:54 PM
Hammer Head Hammer Head is offline
there is no crank angle sensor on a dx or cx dizzy. only si.
93 LeSabre Coding 41 (Cam Sensor) 43 (Knock Sensor) Paul T LeSabre 2 05-05-2009 06:12 AM
88 SE CA18DE CODE 11 Crank angle sensor dougq Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 05-27-2008 02:22 AM
crank angle codes dualcarb88 '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-22-2006 12:20 AM
HELP! crank angle sensor code on swap amy@af '88 - '91 Civic | CRX | Wagon | Shuttlee 10 07-06-2004 02:54 PM
CODE 4: Crank angle sensor travagliante '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-14-2004 10:34 AM
