Old 01-19-2006, 04:25 PM
dualcarb88 dualcarb88 is offline
Angry crank angle codes
I have a 90 civic DX hatch with a B-18 5 speed from a 91 integra. I dont know the history of the swap...(problem #1) Tried to replace the distributer.... what a nightmare... civic piece doesnt work and the integra piece throws a crank angle code?? re-man distributer.
We have tried 3 distributers on this car. It would fire on 2 of them, but not rev past 3000 rpm, then throw a code
the original dost is a TD-23-U with sqaure plugs.... re-mans come with round plugs????
Thanks in advance for any help
DC
Old 01-19-2006, 10:18 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Re: crank angle codes
First off why you replacing the dizzy (just want to get some more info)?
TD23U dizzy Should be round(connectors). 89 integra dizzy,TD03U is square(cam round).
You got B18A1 or B18B1?
TD23U
Is crank angle only code?
Got any pics of dizzy with square connectors?
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-20-2006, 04:59 PM
It is a B18A1.
Crank angle is only code... I cant image both dizzy that will run the car have bad crank angle sensors??
Car had no throttle responce, found metal shavings under the cap...
I will have pics by sat afternoon...
Car is testing my patience
Thanks
DC
Old 01-21-2006, 01:02 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
assuming the dizzy has been replaced with known working good ones, the problem lies in the shielded wire leads or the ecu.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
AF - Advisor
PS: also, wouldnt hurt to check timing.
Old 01-22-2006, 12:20 AM
duffman868 duffman868 is offline
there is a wirering problem. same thing happened to me
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
