Old 05-06-2002, 11:04 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
HELP! crank angle sensor code on swap
i just dropped in a d16y8 (sohc v-tec) with a P28 (92-95 Si/EX) ECU, and wiring harness. got it all in. the car will crank over but idle really rough (no way i'll get it to actually roll down the street) and i'm getting a code 4 (crank angle sensor).
all the swap instructions say leave that unplugged. WTF?
any info? i need this bastard to RUN!
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 05-07-2002, 12:04 AM
bc4g bc4g is offline
odds are i will be doing this swap too so when you get done with the swap an overview would be appreciated. As for your question I don't know myself but you might give Speedline a call 253-584-8399 or www.speedlineracing.net and ask for Kyle. They are based right up here in Tacoma Wa. They do this stuff all the time or try Madavi Motorsports-they have a toll free number.
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 05-07-2002, 01:59 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
damn, I'm drawing a blank...refresh my memory, where's the crank angle sensor?
SOLD!
Old 05-07-2002, 02:56 PM
amy@af's Avatar
jason...it is a plug that the 4th gen didn't have. it comes up out near the timing belt cover. i followed these instructions:
"Transfer the Si or converted Dx to Si harness to the vtec block. On 96-00 block , ignore the (CFK) crank fluctuation sensor located inside the timing belt cover and the knock sensor at the back of the block on 96-00 civic Ex (D16Y8 block)." that info was Found HERE
this morning i went out at 8 am (40 degrees with a wind chill making it feel like 35) and yanked the p28 (v-tec ecu) and stuck my stock ecu back in, stuck back in my 1 wire O2 sensor & knock sensor and it fired right up. just the v-tec won't work until a v-tec controller is added.
i'm gonna try and still figure out the angle sensor problem. i spent $150 on the harness and $130 on the ECU. i would really hate to not use them and end up using the v-tec controller
if you have any ideas...i am open to hear them!!!
ami
Old 05-27-2002, 05:12 PM
felnblu felnblu is offline
i had to run the wires from my ecu when we did the zc swap. and then we had to swap the wires because we were having the same code and the rough idle.
Old 07-06-2004, 12:49 AM
calgarystreetracer calgarystreetracer is offline
Re: HELP! crank angle sensor code on swap
I am trying to drop a 16 valve sohc vtec from a 1993 del sol in to a 1988 CRX, I am having the same problem with the crank angle sensor code, can you please tell me how you fixed the problem???
Old 07-06-2004, 09:33 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
Waaaaaayyyyyyyyyy From The Dead
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 07-06-2004, 10:19 AM
amy@af's Avatar
Re: Re: HELP! crank angle sensor code on swap
'twas the y8 dizzy. if you look at my last reply imentioned we switched routes and made it work with the a6 parts.
hey t-mo, you can't get to upset at an old post....at least calgarystreetracer did a search first. there are people who have been here for years and still can't find the "search" it seems
Old 07-06-2004, 01:35 PM
T-Mo's Avatar
I am not upset trust me. I like when people search
'93 Honda Civic EJ2
Old 07-06-2004, 01:41 PM
Santas90Si Santas90Si is offline
Registered User
Send a message via ICQ to Santas90Si Send a message via AIM to Santas90Si Send a message via Yahoo to Santas90Si
We should make an honor system for the newbies when they use the search feature...
Old 07-06-2004, 01:54 PM
amitykamity amitykamity is offline
Send a message via AIM to amitykamity
Honestly, I thought the "search" feature was a B.S. way for more experienced AF users to get us newbs off thier backs. However, I found it most useful, and if the search didn't provide enough information, I just started a new thread with information more specific to my problem.
I'm uber glad I found this forum, I'm hoping to make my civic one hot number!
88 SE CA18DE CODE 11 Crank angle sensor dougq Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 05-27-2008 01:22 AM
crank angle sensor and speed sensor?? euro735 7 Series 1 04-09-2006 07:45 PM
Location of the coolant temp sensor and the crank angle sensor buddy timms '71-'87 Civic | CRX 1 12-17-2005 01:08 AM
CODE 4: Crank angle sensor travagliante '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-14-2004 09:34 AM
Need some help with crank angle sensor mengy '88 - '91 Civic | CRX | Wagon | Shuttlee 6 09-24-2002 11:33 AM
