Old 04-13-2004, 11:28 PM
travagliante's Avatar
travagliante travagliante is offline
CODE 4: Crank angle sensor
okay about 2 days ago, i was replacing my distributor seal and timing belt. Well anyway i did that and when i starter er up. It idles really bad and sometimes dies. But when i rev it it wont go past 3-3500 grand. When i get there its weird it almost like bogs down like its a limiter or somethin. It only does it when it throws a code.
I can be driving and if i click the key of and back on and pop start the engine the code may not come back on or it will, otherwise it drives fine when not throwing code besides a ruff idle.
Can anyone thats had this problem or had any sugguestions give me some input?
Thanks
Old 04-14-2004, 01:30 AM
slammedcivicsi's Avatar
slammedcivicsi slammedcivicsi is offline
Re: CODE 4: Crank angle sensor
the sensor is inside the dizzy.....so you got a bad dizzy.....or bad ecu....I would assume bad dizzy.....or if you have done the MPFI conversion....one of your wires could have come loose.
89 DX: LS Powered
88 CX: Project ZC
Old 04-14-2004, 09:34 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id say dizzy, the same thing happened to me when i tried putting an si dizzy on my dx, it just dont work.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
