Old 08-08-2002, 10:40 PM
obsidian66 obsidian66 is offline
Batery Relocation
Has anybody relocated there battery to there trunk to leave some more room by the engine, or is it a stupid idea?
Old 08-08-2002, 11:09 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
I've done it in one of my old cars simple and leaves plenty of room for an ignition...charge pipes...99-00 si intake...whatever...summit has kits real cheap...or get an optima battery and you wont need a box.
SOLD!
Old 08-08-2002, 11:10 PM
Ya thats what i was planning on getting. Thanks for the input.
Old 08-08-2002, 11:44 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Yeah, I'm going to be doing the same thing soon, going with an Exide Orbital battery...
Old 08-09-2002, 08:36 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
i did it. its fairly simple. i got a terminal to join all the positive lines together and mounted it on one of the existing holes in the fender wall from the stock airbox. then i used my already existing stereo amp wire as my main positive line. mounted the battery in the back, made a 2 foot long ground (or earth, if youre aussie) and fastened it to one of the bigger studs that hold the back seat in. right now its doing fine, even with that tiny stock battery. soon ill get a better battery, and then run a new lead to my amp.
Old 08-09-2002, 03:21 PM
ci5ic's Avatar
I really hope that the amp-wire that you're using is really big! If your wiring guage is too small, you can start a fire in your car.
Old 08-09-2002, 03:25 PM
turbcivic's Avatar
turbcivic turbcivic is offline
incucivic, you've got a std with a b16? Want to do that too. How hard was the wiring and the swap and what do you run?
Old 08-10-2002, 08:51 AM
EF You's Avatar
EF Life Giver
the amp wire is big, like jumper cable big.
the swap wasnt too hard considering i had a CRX Si sitting in front of my house with the b16 in it, and i just pulled everything from it. the problem comes with the wiring, i used the CRX engine harness, but retained my STD main harness. i had to make a subharness for this, because there are more plugs on one side of the engine bay and a different shaped plug on the other side of the engine bay. it runs, thats about it. as far as 1/4 time, its not so hot right now, i have some serious issues to work out, but it ran a 16.7, this was with the motor not even running about halfway through 3rd gear. it likes to kill in VTEC in 3rd gear, dunno why
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Car not starting I unplug batery wait 60 sec it starts Help monkglen Sportage 9 01-02-2006 12:06 PM
Best/highest quality batery andy2005 Engineering/ Technical 19 12-04-2005 12:40 AM
Weird stall Batery problem uberben Grand Cherokee | Grand Cherokee SRT8 1 09-15-2004 03:48 PM
Bad Starter and reversed batery! latinocheech Escort 4 07-08-2004 06:03 PM
batery problems..... cas4067 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 07-01-2004 04:21 PM
