| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
compression ratios....
why is lowering the c/r better? cuz however i think of it...a higher c/r would mean more air turbulence and wouldn't that be more volatile? and if its more compressed and then you ignite it...wouldn't it be more efficient? or am i totally off...cuz i have nothing to base it on....
yes, a higher c/r makes a more efficient combustion, but you can only compress gas so much before it detonates. this is rated by its octane number. the higher the number, the more you can compress it before detonation.
when you slap a turbo on a car that already has to run on premium, it is most likely going to detonate. because a turbo compresses air and forces it into the combustion chamber, then you have the piston that will compress that air/fuel even more. so either you would have to use racing gas with a higher octane rating, or you would have to lower the engines compression ratio, so it could run on pump gas. |
lower cr is better for running a turbo, but if your staying na, then stay with a higher cr
very cool...thanks yall.
i will somewhat disagree with this
just my 2 cents |
yeah me too, running a low CR is good for mileage and efficiency also
huh? you meant a high compression ratio for efficiency, right?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me... |
Here read this http://www.automotiveforums.com/vbul...5&pagenumber=1
I was arguing about the cr with MatT3T4 but i finally understand him. So read it and u'll know why
