Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-07-2002, 05:44 PM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
how to lower compression ratio?
don't you need to have a lower compression ratio to run big boost from a supercharger or turbo? say if you have a gsr motor. or a b16. how would you go about doing that? cuz i've seen some pistons that raise compression. isn't that bad? i haven't seen any that lower compression ratio. and since you would need to replace internals...........
Old 03-09-2002, 07:10 PM
VTECseoul VTECseoul is offline
Send a message via AIM to VTECseoul
there are Co.s & shops that can get you dish pistons, it'll drop the CR down to 8.8 or 8.5 - but you don't have to lower the CR, even w/ high boost. just use the right fuel (premium or race gas [not legal on street]) & have the motor tuned correctly to take the boost it's given.
2000 Honda Accord LX Satin Silver Sedan
AEM ColdAirIntake
Neuspeed Sport Springs
Nitto 450 225/50
Prime Racing M8 17x7
S15 vs AE86 - 2006 HotWheels Touge
Old 03-09-2002, 10:22 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
he's right, though if you do want to lower thicker head gaskets are an option also
Old 03-10-2002, 01:23 AM
Rgacke's Avatar
Rgacke Rgacke is offline
how much do those head gaskets lower C/R? and wouldn't they increase the chances of blowing a head gasket because of the more exposed area?
"shut the door Joshua, and let death pass by..."
Old 03-11-2002, 04:48 PM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
Getting some headwork done would increase the size of your combustion chamber, thus lowering the compression.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 03-11-2002, 05:59 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
race gas is legal as long as it's unleaded. it's about $4.50 a gallon here.
How to measure compression ratio capriceowns General Discussion 7 03-15-2010 05:41 AM
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 11:10 AM
lower compression ratio? importartist Engine, Transmission and Drivetrain 2 04-06-2005 03:43 AM
Lowering Compression Ratio QuakeWork120 Forced Induction 8 04-20-2004 11:05 PM
lower compression ratio Crippy Engineering/ Technical 2 01-30-2004 10:07 AM
