Old 04-20-2006, 07:22 PM
The LH The LH is offline
Send a message via ICQ to The LH Send a message via AIM to The LH
Compression Ratio = Gear Ratio??
Is the Compression ratio also called the Gear ratio?
I have a 2004 350Z and the compression ratio is listed as 10.3:1 and I wanted to see if that's the same as gear ratio.
I'm having a custom supercharger built and I need to know. The 350Z forum isn't very active so I thought I would ask here. Any help would be greatly appreciated.
Old 04-20-2006, 07:29 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Compression Ratio = Gear Ratio??
no, compression and gear ratios are two completely seperate -not even connected in the slightetest ways- things
Old 04-20-2006, 07:34 PM
Ok, I found the gear ratio for a manual. I can't find anything on yahoo or google for an automatic. Any ideas? Call a dealership maybe?
Old 04-20-2006, 07:37 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
compression ratio is the volume in the cylender at bottom dead center divided by the volume of the cylender at top dead center. so a 10:1 compression ratio means that there is 10 times more volume when the cylender is at the bottom then when it's at the top.
gear ratio is just the ratio of the input speed vs the output speed, or input torque vs output torque. it's usually speed. so a differential that sais it's 3.50:1 means that the input shaft will spin 3.50 times when the output shaft spins once. i dont know if this is clear, im not very good at explaining some things. someone clear it up.
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 04-20-2006, 07:49 PM
Ask.com got me this
04 350Z Roadster
Final Drive Gear Ratio = 3.357
That look right?
Or am I going to look for ratios from 1st gear all the way to 5th gear?
Old 04-20-2006, 08:04 PM
well i dont know why you'd want the final drive ratio for a supercharger. you'd want the compression ratio because it will determine how much boost you can run. do a search in this forum and the forced induction forum for octane, or boost, and look for something that tells you about it, there are countless threads about it.
Old 04-20-2006, 09:50 PM
Ok. Thanks for your help. I hope this turns out the right way. I've spent a lot of money for it not to turn out the right way, and that would suck.
Old 04-21-2006, 10:51 AM
drunken monkey's Avatar
Razor Sharp Twit
might be a strange question but wouldn't the guy making the thing for you be able to tell you?
Old 04-23-2006, 10:10 AM
You would think. It's all worked out now. Thanks for your help. Prolly would have been screwed up if you all didn't help. Many thanks!
