Old 01-21-2002, 11:27 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Timing belt is loose!
Hey sup!My timing belt is very loose! How do i tighten it? I don't think its safe for me to drive it? Please help!! Thanks!
Old 01-21-2002, 12:10 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
if it's loose, dont drive it.
there should be an auto tensioner that automatically keeps tension on the belt as it wears and stretches over time... possibly it's broke.
check the tensioner nut and make sure it hasnt loosened up.
Old 01-21-2002, 03:14 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Don't even start it!!!
I'd recommend you get it towed to a dealer or a competent mechanic. If the belt has skipped a tooth, you may well destroy your engine if you just tighten it back up.
Best of luck.
Old 01-21-2002, 03:20 PM
mellowboy's Avatar
Ok so what do i need to do then? Change the belt? Well i don't know if i should spend anymore money on my stock anymore? I have the b16 but its not installed but its not gonna be installed till the end of march? I need something to drive now and like i said i don't wanna spent too much on my d16 motor. What is the cheapest way of fixin this problem?
Old 01-21-2002, 05:04 PM
mellowboy's Avatar
Ok i just checked my timing belt and the bottom belt has some tear in it? Like the teeth marks that grips the cam gear.So how much do the timing belt go for? I'm gonna have a friend install it for me.
Old 01-21-2002, 05:58 PM
2HOTINTEGRA69 2HOTINTEGRA69 is offline
Send a message via AIM to 2HOTINTEGRA69
Belts are expensive at all. I brought my teg to the dealer and changed the timing belts, all the accesory belts and the water pump for $600. they changed all the fluids too for me. (im such a flirt with those boys at the acura dealer lol) the belt on my teg wasnt broke but my car was hitting 100,000 miles and i figured id change it before it did break. that happened to my bmw and it tore the whole engine apart. its hard work changin the belt u have to unmount the whole engine so make sure your friend knows what hes doin because if its attached wrong the car might not even start. best of luck to u. bye
Old 01-21-2002, 06:01 PM
i meant not expensive sorry like around $30 i think
Old 01-21-2002, 09:17 PM
CHRIS200T CHRIS200T is offline
Send a message via AIM to CHRIS200T Send a message via Yahoo to CHRIS200T
If you want cheap just change the belt. Out here in Ca. I charge about $130.00 labor plus the belt which is about $16-22.00. Buy the cheapest belt you can find as they are all about the same. If you were going to race the car I'd use only top quality racing brands or OE. If you were going to keep the car I would also change the front Camshaft and crankshaft oil seals and waterpump when I did the belt. Whatever you do don't use cheap parts if you're going to keep a car. Fueler
Chris Allen (North San Deago.)
96 200SX GTIR Powerd 497WHP on C16 351WHP on 91 oct pump gas
92 Sentra SE-R Almost stock
91 NX2000 SR20VE VVL Powered 177WHP almost stock (Girlfriends Car)
Old 01-22-2002, 01:49 AM
mellowboy's Avatar
Well i'm just gonna change just the timing belt cause i'm not gonna keep that engine for long
Old 01-22-2002, 03:29 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
You would charge only $130 for labor? My brother in-law has a 88-91 HB. Not sure what year it is. But its the same engine as my CRXDX. He told me that a mechanic said that they needed to change their timing belt and that it was going to cost $400.
R.I.P. - You shall be resurrected.
Old 01-22-2002, 09:01 AM
mellowboy's Avatar
Thats what i thought also? I mean 130 bucks is freakin cheap!! I wish they would've charged me that price around here!
Old 01-22-2002, 05:53 PM
integr8 integr8 is offline
Send a message via Yahoo to integr8
It sounds like it is just the belt. An actual Honda timing belt should cost you between $50-90. If your not going to drive on that engine much longer thats all Id do. Hope the guy that doing it for you knows what hes doing. Have him check the tensioner while hes in there. That price sounds good just for the belt change. The reason dealerships charge $500 or so to change the timing belt is because they change all other belts and the water pump...sometimes even the tensioner while thier in there. Its pretty much just preventative maintinence and it saves you alot of labor to just have it all done at once rather than go back and pay the same labor when the water pump or something else goes out later. I know, Im having all that done as we speak. Blew a head gasket and Im having everything that can be done...done while thier at it.
"Nice body kit, looks good in my rear veiw"
Old 01-22-2002, 09:40 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
when i had my timing belt changed, i had a local shop do it.....dont care to mess with dealers much...i used to work for one. i only payed 260 ..that was parts and labor...all belts, seals and a new water pump..
Old 01-23-2002, 09:47 AM
mellowboy's Avatar
Well a friend of mine is gonna do it for free. All i have to do is provide the belt.He just told me that he done timing belts before so he said he can do it with no problem
Old 01-29-2002, 04:55 PM
pvang31019 pvang31019 is offline
it should only take about 2 hours to do a timing belt on a honda....Mechanics charge flat rate per hour. So if they were to charge you 400 bucks for the labor, they're ripping you off.
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
88 colt timing belt loose and wont start ronald_durst Colt 1 09-23-2007 11:36 PM
Timing Belt loose...Help! integra111 Let's get Technical! 4 07-11-2004 06:56 PM
Timing belt loose! Belt tensioner? integra111 Prelude 2 07-11-2004 10:28 AM
