Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-10-2004, 05:38 PM
integra111 integra111 is offline
Send a message via AIM to integra111
Timing Belt loose...Help!
The other day i notice my car making a weird niose i poped upen the trunk and noticed it coming from the timing belt area. i took the top timing belt cover off and to look at the belt. The belt on the left side is all loose and on the right side is tight. What could of happened here!? Whys it like that, what should i do??
Thx for any input
Old 07-11-2004, 08:02 AM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Timing Belt loose...Help!
Tighten it, maybe, call me kooky.
Old 07-11-2004, 10:26 AM
i think my tensioner broke..Otherwise how would it unlossen itself
Old 07-11-2004, 11:34 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
Loose bolt somewhere? I just suggest you figure it out before you drive it.
Old 07-11-2004, 06:56 PM
riccimangan riccimangan is offline
you should have a tensioner wheel on it. just tighten it up a little and you should be fine but if you think its been slipping then the timing is probably out, and if it is you could f*ck up the engine by cranking it so take out the spark plugs and crank the engine by hand to make sure it's turning smoothly,,,,,,,,,.........,,,,,,,.good luk
