Old 07-03-2009, 11:54 AM
cobraprince cobraprince is offline
timing belt and water pump :(
My water pump went out and my timing belt tore up and broke. I have never replaced either and I was wonder if anyone give me some in depth detail about how to change them properly? Any help would be great.
Old 07-03-2009, 05:48 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: timing belt and water pump :(
If timing belt broke then your engine (at least the heads) is fucked.
Old 07-03-2009, 10:57 PM
quackmandude quackmandude is offline
yea man, more then sure u bent all ur intake valves. taking the heads is not something we can just walk u through, my advice is to get a good, great mechanic to do it. its gonna cost u alot in labor man
SAMSUNG-SGH-I617/1.0 Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 7.6)
Old 07-04-2009, 10:24 AM
Girly VR-4 Girly VR-4 is offline
What year/model is your car? If you have a SOHC (base model stealth, or 97-99 base model 3000GT), then your engine is just fine. But if you have a DOHC engine (every other model, r/t, es, TT stealth, or SL VR-4 3000GT), then I'm sorry to say, your engine will need to be replaced.
When the timing belt breaks, the valves in the head bend. USUALLY, you only REALLY need new heads, but for the price of swapping heads, it's cheaper and easier to get a good used engine and just have the whole thing swapped in.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 07-04-2009, 06:18 PM
I have a `94 base model (SOHC) Do you think I may need a different engine?
Old 07-04-2009, 07:41 PM
if its sohc ull be ok.
Old 07-04-2009, 09:59 PM
Stealthee's Avatar
If its a SOHC you have a 99% chance of being safe.
Old 07-05-2009, 12:56 AM
vectorspecialist vectorspecialist is offline
ur likely fine, when you get the belt and pump fixed, turn it on and listen to it idle, if no weird sounds, drive it a short distance, if still nothing you're fine
yup, here i am
Old 07-05-2009, 09:13 AM
Alright, Thanks you guys. I will get started on that today.
Old 07-05-2009, 11:44 AM
Okay, I've got the pump off and new on. But the only problem that I think is left is that my timing belt and I don't know how to set the timing back. Can anyone help me with that problem?
Old 07-05-2009, 12:35 PM
just make sure you got ALL of the old gasket residue off. If not, you'll have to take everything back off, and do it again. even the smallest piece will cause it to leak.
www.stealth316.com should have a page that shows you how to set the timing.
www.3swarehouse.com
Old 07-06-2009, 11:33 PM
OKay, I went back and double checked the gasket and noticed that the new water pump had a spot for a bolt that I didn't have... well.. to make things easier to explain:
Whoever was messing with the water pump before me broke a bolt head off and now it is flush with the surrounding metal So I can't even get another bold out to start thinking about puting my new water pump back on...
And as you all know I am not the smartest cookie when it comes to mechanical stuff and I'm kind of new to it... so is there anyway possible to get that bolt out so I can get a new one in?
Old 07-06-2009, 11:46 PM
Stealthee's Avatar
THe "bolt" flush with the surrounding metal sounds like the screw that goes in thru the backside.
Old 07-07-2009, 10:01 AM
Take a picture of it. If it's a snapped bolt, you'll need to drill and tap/re-thread it.
www.3swarehouse.com
Old 07-07-2009, 01:51 PM
Ok... How would I get to this bolt if it comes through the backside?
Tags
belt , pump , stealth , timing , water
