Old 04-15-2004, 09:29 AM
ashishkohli ashishkohli is offline
Exclamation Car wont come out of park...
I am having to use the shift lock to get my car out of park. It wont budge otherwise...what could be causing this??? I am having a feeling its a bad transmission...
Old 04-15-2004, 11:10 AM
GideonLS GideonLS is offline
Re: Car wont come out of park...
I am no where near a level that I could offer any serious help here.
But the one thing I would say to check would be that the shift lock is disengaging when you press on the brake pedal to shift. If its nice and quiet around you should be able to hear it when it disengages in your shifter, or, if you press the button on the shifting arm, and while keeping pressure on it, press the brake pedal, with the brake depressed slowly ease up on the button, doing that I think you can hear it better and also feel it a little bit when the locking mechanisim disengages.
I would check that, because if I am correct I think that the shift lock device taht requires the key is to override that, and cross your fingers that is the problem, I would imagine it would be much cheaper than transmission work.
G'luck.
Old 04-16-2004, 02:14 AM
Accupatriot44 Accupatriot44 is offline
"shift interlock", yes that is the problem, apply firm pressure to brake pedal if it will not disengage, you cat look for a small plastic cover in the trim near the shifter, remove it and use your ket to depress the button in there, shift to neutral then start the car. you can then shift into drive etc. then go to the dealer...
Old 04-26-2004, 08:34 PM
Ladyenvy Ladyenvy is offline
Send a message via AIM to Ladyenvy Send a message via Yahoo to Ladyenvy
Smile hello
I am a newbie here. If anyone would like to chat about cars and stuff just let me know. Peace
LE
Old 04-26-2004, 08:36 PM
I have had that same problem with my interlock switch. I took it up to the dealership and found out that my horns had something to do with blowing out my fuse. And ended up paying 86 dollars for a 1 dollar fuse. So check that out and let me know if that worked.
Old 04-29-2004, 06:13 PM
dstjohn dstjohn is offline
I just fixed the exact same problem on my '94 Accord - turns out the brake switch (which disengages the cruise control and shift interlock) died. $27 for a replacement at Autozone and about ten minutes of labor and everything was working. You'll have to squeeze under the steering wheel on your back to reach the switch (the brake pedal rests against it) but it swaps out easily.
Of course, I was driving around without brake lights for over a week before I thought about fixing this, so check this switch right away.
Old 04-30-2004, 08:42 AM
You know it was that 2 lol. I found out that American Honda did a recall on the brake lamp switch aswell.
99 Yukon wont come out of park samsam12345 Yukon 5 09-06-2007 12:32 PM
96 mtc shifter moves but wont come out of park djonessr Monte Carlo 1 11-30-2006 11:00 AM
Wont come out of park gavin_55 General Discussions 1 12-21-2005 10:03 PM
help, wont come out of park unless.. tammyo Taurus | Taurus Wagon 3 01-13-2005 06:51 PM
94 Buick lesabre abs light blinking-wont come out of park! dosmegabyte LeSabre 1 10-25-2004 09:38 PM
