Old 04-12-2004, 10:50 PM
MoshimoGTP's Avatar
MoshimoGTP MoshimoGTP is offline
Send a message via MSN to MoshimoGTP
!!! ABS & "Check Tire Press" Light On! HELP!!
Today, i was driving my car and both lights turned on out of nothing. I noticed that the power steering feels little harder. I sent my car to the mechanic shop and diagnose my car with OTC Tool but no codes were found. What can I do. I tried the ABS braking and the front wheels got locked, then i supoused that front ABS System doesn't work. Please help me !!!!!... I hate that lights on my dashboard.
Thanx
MoshimoGTP
97 Coupe GTP
96K Miles
Old 04-13-2004, 11:42 AM
sonhasteg sonhasteg is offline
Re: !!! ABS & "Check Tire Press" Light On! HELP!!
This has happened to my wife's GTP...I disconnected the battery, removed the wheel sensor connectors and blew them out with compressed air. Plugged them back in and reconnected the battery.
Hope that is all it is with your car. Other's have reported that their wheel sensors have gone bad.
Also, there is a button to reset the Check Tire Press light under the dash on the drivers side. Since your ABS light is on too I don't think that will help, but can't hurt.
Good luck
Old 04-13-2004, 07:08 PM
gtgp97 gtgp97 is offline
Send a message via AIM to gtgp97
same thing happened to my car a couple weeks back...i just reset the tire pressure system and turned the car off. when i turned it back on everything was fine.
Old 04-13-2004, 10:36 PM
MoshimoGTP's Avatar
Sonhasteg, that really works =). Thanx you a lot!
Old 04-13-2004, 11:00 PM
rockford0384's Avatar
rockford0384 rockford0384 is offline
yeah it worked for me to, for about 2 months until i was 2400 miles away from home and my wheel bearing was humming that why mine came on, your about the mileage when they do go. check it out test it see if the wheel moves from top to bottom if you have play, its not good that your problem. (jack you car up to check it out FYI) if you need pics to do it yourself let me know i took about 30 pics while doing it to help people out on what to take off
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver,
still trying to figure out how that happened
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 04-14-2004, 02:23 AM
MoshimoGTP's Avatar
Thanx Rockford, if you can please send me the pics to do the test with my GTP, my car has 95k miles. My email is [email protected]
Thanks!
MoshimoGTP
Old 04-14-2004, 10:50 PM
I sent 9 pics on how to take of the wheelbearing, i would have sent more but i have dial up and it took 50 minutes just to upload those 9. If you still have questions let me know ill try to help you out
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 04-14-2004, 10:58 PM
MoshimoGTP's Avatar
Thanx rockford...
MoshimoGTP
Old 04-15-2004, 11:43 PM
niiice's Avatar
niiice niiice is offline
I have a '97 GTP and the abs and tire press. lights came on. Hooked it up to a scan tool and found that it was the hub assemblies. I replaced them both and now it's fine.Autozone sells the hub assys. for $123.99 each. I took the old ones apart and found a lot of water in them. This seems to be a very common problem. It's a pretty quick and easy fix though. Hope, that helps!
ABS & All Trac Dash Lights On PA Dan Peters Park Avenue 7 12-20-2009 10:28 PM
ABS and Check Tire Pressure Lights on BIGPROFITT Grand Prix 8 01-20-2009 06:18 AM
ABS, TRAC, & Check tire pressure lights on?? goldeelocks Grand Prix 26 07-02-2005 12:41 PM
abs-trac off-check tire press lights on...still pitapit Grand Prix 7 04-27-2005 12:21 AM
ABS, Trac and Tire Pressure Lights On goldeelocks Grand Prix 11 09-07-2004 03:58 PM
