Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-28-2008, 11:54 AM
BIGPROFITT BIGPROFITT is offline
Send a message via Yahoo to BIGPROFITT
ABS and Check Tire Pressure Lights on
I have a 1997 Grand Prix. The ABS and Check Tire Pressure lights are both on and the Traction Control light is also on. Tire pressure is good. No problem braking. What could be causing this? Thanks.
Old 05-28-2008, 01:31 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: ABS and Check Tire Pressue Lights on
You probably have a wheel hub/speed sensor going bad, or the wiring to the speed sensor is corroding. The entire hub/sensor would have to be replaced if it's a bad wheel hub as these are not serviceable and come new and sealed as one unit. A good idea would to find an ABS capable scanner to pinpoint the wheel that's tripping your ABS light. If you need to replace the hub, don't use the cheap aftermarket Chinese crap, it'll just give you more heartche/trouble..
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 05-28-2008, 06:37 PM
That makes sense. Thanks for the advice. The Advance Auto Parts website (www.partsamerica.com) sells a wheel speed sensor:
http://www.partsamerica.com/productd...tNumber=DR1023
I did just think that it only came on yesterday after it rained really hard. I will clean the contacts on the sensor connection and see if that helps.
Old 05-28-2008, 06:49 PM
If you need to replace your hub. An AC/Delco or Timken replacement would be your best bang for your buck.
4 door sedan
No Mods
Old 05-28-2008, 07:08 PM
So even though Advance offers the speed sensor as a replacement part, I will still have to replace the entire hub?
Old 05-28-2008, 08:18 PM
That's correct, the speed sensor is connected to the hub as one unit. Unless you have wires that are bad/corroded leading to the hub, those can be serviced but if you have a bad sensor/hub, it has to be replaced as a unit.
4 door sedan
No Mods
Old 06-09-2008, 05:24 PM
How do I determine which wheel speed sensor/wheel hub is causing the problem, without paying the dealer a fortune to test?
Thanks
Old 01-20-2009, 02:47 AM
helicopter23 helicopter23 is offline
Re: ABS and Check Tire Pressure Lights on
These 3 lights have been coming on too. The always come on when the road is wet and they also don't come on until I am driving for 15 minutes. Is this probally the same above problems?
Old 01-20-2009, 06:18 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but this is an old thread so it has been closed. Just start a new thread addressing your problem following the guidelines below and I'm quite sure you'll get help.
Also, be sure to post the year and model Grand Prix which I am assuming is a '97 model since you have the low tire pressure system.
Old Thread Guidelines
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
