Old 04-16-2005, 06:13 PM
pitapit pitapit is offline
Angry abs-trac off-check tire press lights on...still
i am the unfortunate owner of a 1998 grand prix gt...whos lights will not go off..the abs, check tire pressure and trac off lights have been coming on...noticed they would come on when i accelerated and heard a click at the same time....took it to a transmission place they scanned it and said it was the left front wheel...next up new tire rods were put in ....lights were still coming on....diagnostics still indicating the left front wheel, so then onto a new hub assebly for the left front wheel and alas the lights have come back on yet again shortly after picking up the car...any other ideas as to what might be causing this problem would be greatly appreciated!
Old 04-16-2005, 06:24 PM
jchavis jchavis is offline
well heres my guess. Did you reset the computer? Yellow button under dash. If you did it might be one of the sensors in the front left. Make sure all the little sensor plugs in the wheel well aren't broken, loose, dirty. If that doesn't work take it the dealership or ignore it.
'99 Grand Prix se - Commuter car!
U-Bend delete and ghetto CAI
Old 04-16-2005, 07:27 PM
jimmytroanoke jimmytroanoke is offline
Did they replace the sensor when they replaced the hub? Some come with a new sensor and some don't. I have it on good authority from a GM tech that those sensors usually go to sh!t when they are removed from the old hub. If the sensor is not reading right your ABS will not function - Normal brakes fine.
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 04-16-2005, 08:24 PM
Re: abs-trac off-check tire press lights on...still
[quote=jimmytroanoke]Did they replace the sensor when they replaced the hub? Some come with a new sensor and some don't. I have it on good authority from a GM tech that those sensors usually go to sh!t when they are removed from the old hub. If the sensor is not reading right your ABS will not function - Normal brakes fine.[/QUOT
well i tried the reset button to no avail...at least now the lights dont all come on automatically....takes a number of acceleratoins....will talk to the mechanic on monday and see if he put a new sensor in....receipt dosent indicate...
Old 04-18-2005, 11:35 AM
mtpina mtpina is offline
Send a message via Yahoo to mtpina
tire pressure
can someone post a picture of the tire pressure button, since i can find it '00 Grand Prix GT
Old 04-25-2005, 01:05 PM
John Carroll John Carroll is offline
Iam also having the same problem with my abs,trac off and tire presure lights, and now my seat belt and check engine lights are on as well help would be great,I changed my drivers side hub and tried the reset button.
Old 04-26-2005, 11:34 PM
MIGTPGUY MIGTPGUY is offline
Send a message via AIM to MIGTPGUY
Im having the same problem the last month...ever since i got an Intense PCM... maybe just a coincidence... same exact thing your describing..... when i go WOT the lights come on and i lose ABS.... almost caused me to get in accident few days ago when MI got a foot of snow.
Old 04-27-2005, 12:21 AM
Re: Re: abs-trac off-check tire press lights on...still
well its been over a week now and magically the lights have gone off....the mechanic seems to think it was the wheel hub and sensor replacement that took care of the problem..it just took a few drives after to get the lights off...they think the problem dated back to being stuck in the snow this past winter....maybe that will help!
