Old 04-06-2004, 12:06 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
compression ratio
Why is the compression ratio better for holding high boost when it is lower? And on Dsms is it still safe to run 15 psi on 8.5:1 compression ratio? lets say you have supporting mods and a stock turbo.
Old 04-06-2004, 01:13 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: compression ratio
It doesn't 'hold boost' any better, just remember that more compression at some point equals knock. If you lower compression, you can run more boost before you hit knock (the point where you can't make any more power) for that situation.
15psi on a stock turbo comes nowhere near the max compression before knock, so yes, it's safe.
Old 04-06-2004, 01:20 AM
ok cool thanks a lot Joe...but when you start increasing boost udner 20psi with a bigger turbo, why do some people say it will decrease the longevity of the car?
Old 04-06-2004, 03:52 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
any power mods that you do to any car will decrease the life length! thats a given fact! see if you start cranking up the boost it makes the engine work harder... there for when it has to work harder it wears out quicker! understand?
Old 04-06-2004, 04:10 AM
kjewer1 kjewer1 is offline
AF - Advisor
All of the guys running serious boost (over 30 psi) are actually running INCREASED compression ration. Typically 9:1. I'm a hair under 9:1 and I run 25 psi on pump gas with no issues (the car is setup for that of course). The theory is there, but in real life on a properly set up car, you dont have to hose the compression ratio jsut to avoid knock. Thats just another bandaid. But naturally there are limits, and you dont want the CR of a honda if you intend to run high boost and low octane fuel.
The thing to remember is knock is from heat. Heat is from cylinder pressure. Cylinder pressure is airflow (power), heat (boost/inefficiency/intercooling), compression ratio.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
compression ratios and method of compression SPOOK(I) Impreza/9-2x/Outback Sport 2 05-28-2013 06:26 PM
Compression Ratio = Gear Ratio?? The LH Engineering/ Technical 8 04-23-2006 10:10 AM
Compression Ratios....drift..your sarcasm welcome hehe VTEC_boi Engineering/ Technical 16 03-18-2004 06:30 PM
how to lower compression ratio? liquid8 Forced Induction 5 03-11-2002 04:59 PM
compression ratio b16b bomber '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-23-2002 12:47 AM
