When I shift into reverse from park, a loud clanging noise (sounds like a hammer hitting a steel pipe) happens. It also happens again when I shift into drive and start to accelerate. It sometimes happens when I'm at speeds of 20-40 mph and I take my foot off the gas and as soon as I push to accelerate....CLANG! Please Help.
I got's the same darn noise, cant figure it out. if you turn it off and put it in park, rock it forward and back you can hear only that sound but I cannot tell where the sound is originating at. PLEASE HELP its very annoying and i would like to get rid of it ASAP.
Thanks in advance |
Re: Noise when shifting to reverse and accelerating
I know a car that had that sound i think, is it auto or stick?????
Hugs 'N' Kisses Love Lisa
If its a car making that sound its probably CV Axles (auto & manual), but our problem is different. Im hearing that U-joints is the problem but I dont think that is it. I was under there and the driveshaft is solid; wiggled n jiggled no movement.
Fix (maybe)
It seems that a common problem is that either the pressure soleniod or the PWMTCC (Pulse Width Modulator Torque Converter Clutch) control soleniod in the tranny can cause this. Sometimes a simple fluid and filter change will fix this. My 2000 4WD LS is in the shop today having a flush and fill and they're going to look at the u-joints and run diagnostics on the soleniods and let me know. The dealer charges out the a$$ ($300 +) for these items but there's a place you can order the items for around $40 shipped to you. From what I hear it's a pretty easy fix too. I haven't done it because of a lack of facilities. Damned apartment complex.
Did your's have the same clang noise? or are you just in for reg maitenance
Has anyone figured out what this noise is and how to resolve it? Clangs until I reach 20 miles per hour then stops. Got the rear end changed and filled, noise seemed to go away, but its back.
I'm leaning twards U-joints but I am not sure of how they sound when theyre bad. It also sounds worse like a mechanical clang low and annoying. If I slam the gas it will make noise to about 20 mhr.
