Old 03-13-2004, 08:04 PM
gue55wh01t15 gue55wh01t15 is offline
Send a message via AIM to gue55wh01t15
belt tension?
i just changed the compressor/ power stearing belt on my GST and i was wondering how you guage the right amount of tension on the belt. It says 120 lbs but how do i know what is 120 lbs of tension. thnx in advance
"The only constant is change."
Old 03-14-2004, 02:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: belt tension?
Its a judgement call. Tight enough that it doesnt slip, but not so tight it puts excesive side loading on the bearing (good way to kill that accessory).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-14-2004, 12:41 PM
thanx kevin...you da bomb
How to Tighten Tensioner on Serpentine Belt - 05 G6 donnap1957 G6 0 02-26-2009 09:01 PM
Timing belt tension spring's purpose AFTER belt install? Allen McCready Camry/Camry Hybrid/Vista 2 11-26-2004 10:42 PM
serpentine belt tension (w/o tensioner pulley) spender Neon | Plymouth Neon 1 09-19-2004 04:10 PM
Timing belt loose! Belt tensioner? integra111 Prelude 2 07-11-2004 10:28 AM
belt tensioner loosing spring tension?? yzguy Blazer 4 04-09-2003 08:15 PM
