Old 03-30-2003, 07:56 PM
yzguy yzguy is offline
belt tensioner loosing spring tension??
Anyone have a problem with the tensioner losing some of it tension?? My 97 Blazer seems to be letting the belt slip and you can hear it kinda squeaking. I remove the belt and the nose goes away. I tried a new belt, and degreasing all of the pulleys (also replaced the alt, but that was because of noisy bearings). When you look at the tensioner while it is running, it bounces around a lot which is what is leading me to believe it is too loose. Also all of the accessory pulleys spin freely and while running no other part of the belt seems to be flapping, or otherwise loose.
Old 04-07-2003, 03:31 PM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
Take a good look and feel to the idler pulley. I find more times than not this is the culprit of most squeaks on these vehicles.
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 04-07-2003, 07:41 PM
cool, that's my next check.... I went ahead and replaced the tensioner (because the belt was floping quite a bit). It is better now (not flopping around anymore).
Old 04-09-2003, 05:40 PM
Cadd43 Cadd43 is offline
Question replacing tensioner
yzguy, I'm hoping that you could answer some questions I have. You mentioned that you replaced the tensioner yourself.
First thing is how much did it cost?
Secondly Any special tools required?
I had the misfortune of mine going out on me today. Kuckily I was very few blocks from home when it happened. No other damage that I can tell happened. The serpentine belt is still good.
Also if one can do it them selves. Is it very difficult to do. I try to do as much as I can. A Shade tree mechanic I guess. But I know when I'm biting off too much for my own good.
Just trying to save some $$$ if I can.
Old 04-09-2003, 08:15 PM
it is very easy... if you can remove/install the belt and remove and install one bolt you can do it.
Just take off the belt, and get a 1/4 ratchet with the correct socket for the bolt in the center of the tensioner. Remove the bolt and pull the tensioner forward. Just look at the little "peg" sticking out of the tensoner at about 2 or 3 O'clock from the front. This peg must go into the hole for it on the block. Get a new one from the local auto parts store, I think mine was about $35 from Discount. Put the new washer on the new bolt that comes with it (if it does, I'm not sure if all do), line up the peg with the hole, and tighten up the bolt. That's it!!
How to Tighten Tensioner on Serpentine Belt - 05 G6 donnap1957 G6 0 02-26-2009 09:01 PM
tensioner loose? Normal? jsweeter Silverado 3 02-25-2008 12:37 PM
Belt Tensioner Loose Ivan R Malibu 6 02-25-2006 07:23 PM
serpentine belt tension (w/o tensioner pulley) spender Neon | Plymouth Neon 1 09-19-2004 04:10 PM
[1997] Loose seat belt spring tension - is there an easy way to fixing it? 1997Camry Camry/Camry Hybrid/Vista 2 06-01-2004 09:05 AM
